Problem with Homematic Binding and Device HM-TC-IT-WM-W-EU
Hi, I am using OpenHAB 2.4 and I got a problem to control my Wireless Room Thermostats (HM-TC-IT-WM-W-EU). Changing the mode or trying to set a temperature using the app do not change anything and I get the following error in my log:
2019-01-04 09:55:21.223 [ERROR] [ematic.handler.HomematicThingHandler] - null
	at org.eclipse.smarthome.binding.homematic.internal.converter.type.QuantityTypeConverter.toBinding(QuantityTypeConverter.java:58) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at org.eclipse.smarthome.binding.homematic.internal.converter.type.QuantityTypeConverter.toBinding(QuantityTypeConverter.java:1) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at org.eclipse.smarthome.binding.homematic.internal.converter.type.AbstractTypeConverter.convertToBinding(AbstractTypeConverter.java:102) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:281) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at sun.reflect.GeneratedMethodAccessor178.invoke(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
	at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
	at com.sun.proxy.$Proxy139.handleCommand(Unknown Source) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
	at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
	at sun.reflect.GeneratedMethodAccessor177.invoke(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
Is this a known problem? Did not change the configuration of that devices and all my other homematic devices work as expected.
@gerrieg: mabye you got a hint for me?
Thanks for any hints!
Greets Daniel
Looks like a bug in the converter. Can you please create a new issue here
and ask mdicke2s to take a look at it? He implemented the converter and i am on vacation until Feb.
Thanks a lot @gerrieg, have a nice vacation! I’ll create an issue later.
Greets
Daniel
EDIT: Here is the issue for anyone who is interested: Problem with Homematic Binding and Device HM-TC-IT-WM-W-EU (QuantityTypeConverter) · Issue #6802 · eclipse-archived/smarthome · GitHub
