Hello.
I had previously installed OpenHab with the KNX binding and used it successfully, however, now with a fresh install I have run into problems.
I have installed OpenHab via openhabian, on an AMD machine.
I have configured the KNX binding using this Thing:
UID: knx:ip:cb51cfeb6b
label: KNX/IP Gateway
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
ipAddress: 192.168.178.22
autoReconnectPeriod: 60
localIp: 192.168.178.52
type: TUNNEL
readingPause: 50
localSourceAddr: 0.0.0
portNumber: 3671
responseTimeout: 10
When I configure it this way, the gateway is shown in the Running state. So far so good!
But now when I configure some items and channels, and trigger the items, nothing seems to be sent to the bus. Do you have any idea what might be causing this? And is there any way to find out where the events are being swallowed? The log is awfully silent, it merely shows:
14:55:23.052 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'knx:device:28be96c99b:1f45651585' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
14:55:33.440 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Licht_Buro_Licht_Buro' received command ON
14:55:33.445 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'Licht_Buro_Licht_Buro' predicted to become ON
14:55:33.452 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Licht_Buro_Licht_Buro' changed from OFF to ON
