is there a problem with the Miele Cloud Binding (maybe after upgrade on OH3.3.0) oder the Miele API in generell?
My account and my device (CM6560) things are both online, but no commands (turn on/off) are transmitted to the device (–> no reaction).
Here the error from the log:
21:30:40.944 [WARN ] [rnal.handler.CoffeeSystemThingHandler] - Failed to set light state to 'false' for device '000152952134'.
org.openhab.binding.mielecloud.internal.webservice.exception.MieleWebserviceException: Unable to perform operation. Operation failed 2 times.
at org.openhab.binding.mielecloud.internal.webservice.retry.NTimesRetryStrategy.performRetryableOperation(NTimesRetryStrategy.java:65) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.RetryStrategyCombiner.performRetryableOperation(RetryStrategyCombiner.java:44) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.RetryStrategy.performRetryableOperation(RetryStrategy.java:54) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.DefaultMieleWebservice.putActions(DefaultMieleWebservice.java:338) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.DefaultMieleWebservice.putLight(DefaultMieleWebservice.java:223) ~[?:?]
at org.openhab.binding.mielecloud.internal.handler.AbstractMieleThingHandler.lambda$3(AbstractMieleThingHandler.java:185) ~[?:?]
at org.openhab.binding.mielecloud.internal.handler.AbstractMieleThingHandler.lambda$9(AbstractMieleThingHandler.java:202) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.binding.mielecloud.internal.webservice.exception.MieleWebserviceTransientException: HTTP error 500: Internal Server Error
Cloud returned message: Optional[GENERIC_TECHNICAL_ERROR (Error-ID: 8e6e45870dbd023c)]
at org.openhab.binding.mielecloud.internal.webservice.HttpUtil.checkHttpSuccess(HttpUtil.java:66) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.DefaultMieleWebservice.lambda$8(DefaultMieleWebservice.java:347) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.RetryStrategy$1.get(RetryStrategy.java:57) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.RetryStrategy$1.get(RetryStrategy.java:1) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.AuthorizationFailedRetryStrategy.performRetryableOperation(AuthorizationFailedRetryStrategy.java:67) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.RetryStrategyCombiner.lambda$0(RetryStrategyCombiner.java:44) ~[?:?]
at org.openhab.binding.mielecloud.internal.webservice.retry.NTimesRetryStrategy.performRetryableOperation(NTimesRetryStrategy.java:54) ~[?:?]
... 12 more
21:30:48.776 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
I also recognized, that there seems to be a problem in the own app of miele. Its loading very long and my device is not shown:
Thanks in advance,
Alex
