Hi i have a problem with the association of 3 valves to a wall-thermostat.
The first one in the association declaration (htWohnzimmerPosition.mean) works as intended …ure=temperature:associate=MEQ1818437,MEQ1818441,MEQ1818489
The other two get their temp obviously not from the wall thermostat
Set Point for wall-thermostat is 20.5°
(Big Windows & the sun is shining)
are there some hints for me ?
//wtWohnzimmer
Number wtWohnzimmerSetpoint "wtWohnzimmer Current Setpoint [%.1f °C]" (GMaxControlLivingWoZi,GMaxControl,GMaxSetTemp) { maxcul="WallThermostat:NEQ1201965:feature=thermostat:configTemp=21.0/17.0/23.5/12.5/4.5/0.0/0.0" }
Switch wtWohnzimmerBattery "wtWohnzimmer Battery Low" (GMaxLiving) { maxcul="WallThermostat:NEQ1201965:feature=battery" }
Number wtWohnzimmerTemp "wtWohnzimmer Current Temp [%.1f °C]" (GMaxLiving) { maxcul="WallThermostat:NEQ1201965:feature=temperature:associate='MEQ1818437,MEQ1818441,MEQ1818489'" }
Switch wtWohnzimmerDisplay "wtWohnzimmer Display Setting" (GMaxLiving) { maxcul="WallThermostat:NEQ1201965:feature=displaySetting" }
//htWohnzimmer
Number htWohnzimmerSetpoint "htWohnzimmer Current Setpoint [%.1f °C]" (GMaxLiving,GMaxSetTemp) { maxcul="RadiatorThermostat:MEQ1818437:feature=thermostat:associate=NEQ1201965" }
Switch htWohnzimmerBattery "htWohnzimmer Battery" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818437:feature=battery" }
Number htWohnzimmerTemp "htWohnzimmer Current Temp [%.1f °C]" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818437:feature=temperature" }
Number htWohnzimmerPosition "htWohnzimmer Position [%.1f %%]" (GMaxLiving,GMaxValve) { maxcul="RadiatorThermostat:MEQ1818437:feature=valvepos" }
//htFlur
Number htFlurSetpoint "htFlur Current Setpoint [%.1f °C]" (GMaxLiving,GMaxSetTemp) { maxcul="RadiatorThermostat:MEQ1818441:feature=thermostat:associate=NEQ1201965" }
Switch htFlurBattery "htFlur Battery" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818441:feature=battery" }
Number htFlurTemp "htFlur Current Temp [%.1f °C]" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818441:feature=temperature" }
Number htFlurPosition "htFlur Position [%.1f %%]" (GMaxLiving,GMaxValve) { maxcul="RadiatorThermostat:MEQ1818441:feature=valvepos" }
//htKlo
Number htKloSetpoint "htKlo Current Setpoint [%.1f °C]" (GMaxLiving,GMaxSetTemp) { maxcul="RadiatorThermostat:MEQ1818489:feature=thermostat:associate=NEQ1201965" }
Switch htKloBattery "htKlo Battery" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818489:feature=battery" }
Number htKloTemp "htKlo Current Temp [%.1f °C]" (GMaxLiving) { maxcul="RadiatorThermostat:MEQ1818489:feature=temperature" }
Number htKloPosition "htKlo Position [%.1f %%]" (GMaxLiving,GMaxValve) { maxcul="RadiatorThermostat:MEQ1818489:feature=valvepos" }
