I’m using mycroft openhab skill, it works well with switch on/off lights, but I have a problem with dimmer
13:09:28.271 - mycroft.skills.core:wrapper:1102 - ERROR - An error occurred while processing a request in open HAB Skill
Traceback (most recent call last):
File "/home/pi/mycroft-core/mycroft/skills/core.py", line 1093, in wrapper
handler(message)
File "/opt/mycroft/skills/openhab-skill.openhab/__init__.py", line 208, in handle_dimmer_status_intent
if ((int(brightValue) < 0) or (int(brightValue) > 100)):
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'
It seems he is trying to send 50% instead of 50.
If I issue a command set dimmer to 50 it works, but if I say 50 percent it doesnt work.
Dimmer LivingDimmer "Living Dimmer [%s %%]" <light> ["Lighting"] { channel="knx:device:bridge:generic:LivingDimmer" }
How should I configure the item?
Also, when I ask him for what is current living room temperature, he says 36 degrees (he gets outside temperature from the internet, completely ignores the item
Number RoomsTemp "Living Room Temperature" <temperature> ["CurrentTemperature"] { channel="knx:device:bridge:generic:RoomsTemp" }
thanks,
regards,
Vanja
