- Issue of the topic:
Installation of OpenHab like described here
I tried to install OpenHab on a new SD Card on my Pi 4 (8GB)
I used the Debian Bullseye image without Desktop and installed Java V11.0.17
Then I tried the installation of OpenHab like described and the first command ends in an error.
curl -fsSL “https://openhab.jfrog.io/artifactory/api/gpg/key/public” | gpg --dearmor > openhab.gpg
I get the following message:
-bash: openhab.gpg: Permission denied
(23) Failed writing body
Do iI have to install something else before?
Old Version with
wget -qO - ‘https://openhab.jfrog.io/artifactory/api/gpg/key/public’ | sudo apt-key add -
works but I got the standard warning
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
That was the reason I wanted to start with gpg instead of apt-key.
Thanks in advance.
- Platform information:
- Hardware: Pi 4 8GB
- OS: Raspian Debian Bullseye 64bit without Desktop
- Java Runtime Environment: openjdk 11.0.17 2022-10-18 LTS
- openHAB version:
