Problem with previousState in rule for battery alarm
i got a little problem with previousState in a rule for a battery alarm.
I want a broadcast-message at every change of the battery level of my iPad, if its 25% or lower.
To avoid messages during charging, i want the message just, if the previousState ist greater than the actual state.
I created the following rule, but i doesn’t fire.
Woult be great if you could help me to get it running.
Thanks Alex!
rule "Battery_Low_iPad"
    Item IPadVonFamilieIPad_Batterieladung changed
    if (IPadVonFamilieIPad_Batterieladung.state <=25 && IPadVonFamilieIPad_Batterieladung.previousState.state > IPadVonFamilieIPad_Batterieladung.state ) {
    sendBroadcastNotification("Das iPad muss geladen werden, der Akku hat nur noch "+IPadVonFamilieIPad_Batterieladung.state+" %!")
i also tried it with the if-statements in two brackets:
    if ((IPadVonFamilieIPad_Batterieladung.state <=25) && (IPadVonFamilieIPad_Batterieladung.previousState.state > IPadVonFamilieIPad_Batterieladung.state )) {
Unless you have suitable persistence configured on this Item, you won’t get .previousState
Fortunately your rule is triggered off Item change, so you can use the implicit variable previousState which gets populated automatically.
Number Item state comparisons can be picky and it’s usually best to ensure you get them as Number variables.
Try
if ( (IPadVonFamilieIPad_Batterieladung.state as Number) >= 25
   && (previousState as Number) > (IPadVonFamilieIPad_Batterieladung.state as Number)
setting the state to a number works fine, thank you!
