not sure if this is a runtime or (hue) binding problem.
After I had to replace a whole hue starter set with a new bridge and three new bulbs I am getting warnings in openhab. All things (bridge + three bulbs) have been configured in OH2. I deleted the things, set up the new bridge and the three new bulbs and added the things to OH2 again. Then I linked the existing items to the new things.
Now, I am receiving this warning:
15:05:28.163 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '84,47,0' for item 'Hue_Bulb1_Color' to handler for channel 'hue::001788279428:1:color', because no thing with the UID 'hue::001788279428:1' could be found.
15:05:28.180 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'SELECT' for item 'Hue_Bulb1_Alert' to handler for channel 'hue::001788279428:1:alert', because no thing with the UID 'hue::001788279428:1' could be found.
15:05:28.193 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '81,55,12' for item 'Hue_Bulb2_Color' to handler for channel 'hue::001788279428:2:color', because no thing with the UID 'hue::001788279428:2' could be found.
15:05:28.205 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '68,88,0' for item 'Hue_Bulb3_Color' to handler for channel 'hue::001788279428:3:color', because no thing with the UID 'hue::001788279428:3' could be found.
15:05:28.232 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '67,8,0' for item 'Hue_Bloom1_Color' to handler for channel 'hue::001788279428:4:color', because no thing with the UID 'hue::001788279428:4' could be found.
15:05:28.245 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '67,8,0' for item 'Hue_Lightstrip1_Color' to handler for channel 'hue::001788279428:5:color', because no thing with the UID 'hue::001788279428:5' could be found.
The thing (e.g.) “hue::001788279428:1” does not exist, but I don’t know where it is referenced.
I manage my items via item-files and there only the current “things” are present.
Even a removechannel does not work
openhab> smarthome:links removeChannelLink LC_Flur_Temp jeelink:lacrosse:1479642265933:temperature
Could not remove link LC_Flur_Temp -> jeelink:lacrosse:1479642265933:temperature.
FWIW, I just ended up chasing a problem with old links for about two hours before I ran across this post. Very helpful. But @ThomDietrich, I wonder if there is a need for a “Troubleshooting” section, or at least a “Additional Resources” section in the documentation so people can know about these issues? I have developed a number of useful bookmarked links that are essentially additional information that is not included in the current documentation. I am happy to create such a section and seed it with a few links to things I have found to be useful.
