Problem with USB port after reinstall of OpenHAB, cannot read from Smartmeter
I am sorry to bother you with something basic but I am completely lost and can’t find any solution for my problem. I guess it’s dead simple but not for me.
I did a fresh install of OpenHAB to perform a release update. Then I restored my settings from an OpenHAB backup. It worked well but for some reason, I cannot access my electric power values anymore. I use the Smartmeter binding. Sometimes it works for a short time but suddenly the thing goes from Online to Offline. This is the error:
2024-09-30 18:59:22.366 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'smartmeter:meter:Smartmeter2' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): The source did not signal an event for 40000 milliseconds and has been terminated.
2024-09-30 18:59:24.367 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'smartmeter:meter:Smartmeter2' changed from OFFLINE (COMMUNICATION_ERROR): The source did not signal an event for 40000 milliseconds and has been terminated. to OFFLINE (COMMUNICATION_ERROR): No provider for port /dev/ttyUSB0 found
Does anyone have a step by step guide to things I can do and check to resolve the error?
Thank you, Max
Not familiar with that binding, but the zwave binding uses a serial port and needs the feature:install openhab-transport-serial in karaf. Do you recall doing that in the past?
Hi Bob, thank you. I don’t recall that. But thank you very much for your advise. I can try that.
I tried this and I have restarted OpenHAB service but the problem stays. The smartmeter comes online for a couple of seconds but then goes offline again because of the error mentioned in my first post.
