This is OH3.2 in a vm on debian 10.11
openjdk 11.0.14 2022-01-18 LTS
OpenJDK Runtime Environment Zulu11.54+23-CA (build 11.0.14+9-LTS)
OpenJDK 64-Bit Server VM Zulu11.54+23-CA (build 11.0.14+9-LTS, mixed mode)
recently (weeks) fresh install
I see Unexpected exception occurred while processing REST request
recurring like twice daily (estima.)
I’m aware of a few similar posts including
- Unexpected exception occurred while processing REST request. org.eclipse.jetty.io.EofException: null - #2 by kstuken and
- https://github.com/openhab/openhab-core/issues/2651
but the differences are large after the initial line/s.
I have not been able to link those events to anything specific happening.
This is a typical logged exception:
2022-02-03 13:52:06.563 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2022-02-03 13:52:06.566 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30003/30000 ms
at org.eclipse.jetty.util.SharedBlockingCallback$Blocker.block(SharedBlockingCallback.java:257) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.channelWrite(HttpOutput.java:270) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:869) ~[bundleFile:9.4.43.v20210629]
at org.apache.cxf.io.AbstractWrappedOutputStream.write(AbstractWrappedOutputStream.java:51) ~[bundleFile:3.4.5]
at java.io.InputStream.transferTo(InputStream.java:705) ~[?:?]
at org.openhab.core.io.rest.core.internal.GsonMessageBodyWriter.writeTo(GsonMessageBodyWriter.java:84) ~[?:?]
at org.openhab.core.io.rest.core.internal.MediaTypeExtension.writeTo(MediaTypeExtension.java:84) ~[?:?]
at org.apache.cxf.jaxrs.utils.JAXRSUtils.writeMessageBody(JAXRSUtils.java:1543) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.serializeMessage(JAXRSOutInterceptor.java:249) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.processResponse(JAXRSOutInterceptor.java:122) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.interceptor.JAXRSOutInterceptor.handleMessage(JAXRSOutInterceptor.java:84) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30003/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[bundleFile:9.4.43.v20210629]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
... 1 more
