Problems after upgrade to 2.2 (CircularReference, bindings no longer work)
Several users complained that the jeelink binding does no longer work after an openHAB upgrade to 2.2. So I just upgraded openHAB using openhabian-config and now have the same, but also other problems.
The Jeelink binding no longer works. I only get
java.lang.IllegalArgumentException: repeated interface: org.eclipse.smarthome.core.thing.binding.BridgeHandler
I have other exceptions in the log that occur during start of openHAB:
2017-12-10 14:55:21.934 [ERROR] [org.apache.felix.scr                ] - Circular reference detected trying to get service {org.eclipse.smarthome.automation.module.script.ScriptExtensionProvider}={component.name=org.eclipse.smarthome.automation.module.media.internal.MediaScriptScopeProvider, component.id=167, service.id=292, service.bundleid=210, service.scope=bundle}
 stack of references: ServiceReference: {org.eclipse.smarthome.automation.module.script.ScriptExtensionProvider}={component.name=org.eclipse.smarthome.automation.module.media.internal.MediaScriptScopeProvider, component.id=167, service.id=292, service.bundleid=210, service.scope=bundle}
ServiceReference: {org.eclipse.smarthome.automation.module.script.internal.ScriptExtensionManager}={component.name=org.eclipse.smarthome.automation.module.script.internal.ScriptExtensionManager, component.id=170, service.id=295, service.bundleid=211, service.scope=bundle}
java.lang.Exception: stack trace
	at org.apache.felix.scr.impl.ComponentRegistry.enterCreate(ComponentRegistry.java:510) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.enterCreate(BundleComponentActivator.java:809) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:817) [45:org.apache.felix.scr:2.0.12]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:403) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [45:org.apache.felix.scr:2.0.12]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [18:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187) [45:org.apache.felix.scr:2.0.12]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:548) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) [?:?]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470) [?:?]
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) [?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345) [?:?]
	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:407) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364) [?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161) [?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
	at java.lang.ClassLoader.defineClass1(Native Method) [?:?]
	at java.lang.ClassLoader.defineClass(ClassLoader.java:763) [?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:273) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:586) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423) [?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:976) [45:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1003) [45:org.apache.felix.scr:2.0.12]
	at org.eclipse.osgi.container.Module.doStart(Module.java:578) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2017-12-10 14:55:22.026 [WARN ] [se.smarthome.automation.module.media] - FrameworkEvent
@Kai, as you stated we shall come forward with problems that might be related to 2.2: has something changed in openHAB for which binding developers have to make adaptations to the binding? As mentioned in the jeelink binding thread, there are several people for which the binding no longer works after upgrading openHAB.
For what it’s worth, I do get the same exception (java.lang.IllegalArgumentException: repeated interface: org.eclipse.smarthome.core.thing.binding.BridgeHandler) for my elerotransmitterstick binding, which is currently submitted as a pull request. Both no longer work with current versions of 2.2-SNAPSHOT.
Many thanks for bringing this up, this indeed looks like a critical bug to me that needs to be addressed - I have created SafeCallerBuilderImpl fails to create proxy for bridge handlers · Issue #4713 · eclipse-archived/smarthome · GitHub for it!
Latest distro #1130 should have the fix included - please retest and report back!
Thank you for the prompt fix. I can confirm that the exceptions are gone and the bindings work again.
is cloudbees dead…? I’m getting an error.
Yes, I already contacted support…
