One database entry cannot affect another. That change would not reach a snapshot build until sometime after that time.
The database is usually exported to GitHub weekly ( as seen on GitHub) and then picked up by the snapshot build process. I think the export date you see is something internal to the cd-jackson server processes.
Now I did the factory reset. Problem is still there. Of Course a new Node ID is given, but still unknown device. The Danfoss Thermostate wasnât cheap ;). I know that the Neo WallPlugs are not the best, but theyâre my repeaters.
I had other problems with 2.5.0, so I donât want go back to that version.
Maybe I should try the last stable version/milestone?
If you are dealing with battery operated devices wake them up mulitple times. You manual will tell you how to do that.
I did that many many many times (wake up). I did multiple scans and woke them always up when the devices goes to sleep mode. I tried this at âreaddingâ and now at âreincludeâ.
Itâs not my first z-wave device, and I readded about 10-15 devices at the Update to 2.4 and 2.5. Sometimes it was like you said, I had to wake up the devices 2-3 times until it was identified completly. But at this time it is really confusing.
You need to wake them up until the xml file got created.
Is somebody editing the jackson DB? now there is a change from today.
Some people have had to wake them up 20 - 30 times on some of the cheap devices. That is probably why some devices say they stay awake for 5 minutes after first included into a network.
The community maintains it, so likely
There are review checks that must be passed though. Those are only a few select people. I am not one of the âchosen fewâ.
Nope, no changes since two month on both db entries:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/397
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1014
Mine is this one:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/165
This is a NAS-WR01ZE thread:
ah, sorry Iâm in the wrong topic. not my day today.
Donât worry about the edit to LC13, nothing has changed.
Hi, problem with the wallplugs is solved. I shutdown my raspberry for backup purposes. After starting it, i tried again delete and readding all âproblemâ devices again. both wallplugs are discovered without wakeup at first time. only the lc13 is missing. I make a new thread for this. Thanks for your help to everybody!
