The step where is get stuck is at the very beginning: I’m not able to edit the mqtt.cfg. I installed the smart home designer on my Mac which I now think didn’t make sense because I found out it should be on the same system that runs openhab.
When i open Openhab in the browser i cant find any option in any UI to edit the file.
After that i tried to manually edit the file in Raspbian but i cant save because the OS says the file is owned by Openhab.
Too be honest I believe that i’m making some very stupid mistake because editing a file cant be that hard
Is there a possibility to work with the SmartHome Designer though its running on another System?
OK, I was thinking about this possibility. This Morning i tried connecting to my Pi via Remote Desktop and editing the mqtt.conf using sudo nano … and it worked
So first Problem should be solved!
EDIT: Accessing my Pi Via SSH should also work I think but remote desktop is easier for me
