Hi everyone. A problem comes to me. I used to use the bluetooth binding following instrunctions here https://github.com/sputnikdev/eclipse-smarthome-bluetooth-binding, which is a 3rd party bluetooth binding. It works fine until I reinstall the openHAB 2.5.M5 on my Ubuntu using apt, however without uninstalling the old 2.4. Now when I tried to use the same bluetooth binding from eclipse market, I can add my bluetooth adapter and the binding can also automatically discover bluetooth devices. However when I tried to add one of my bluetooth devices as things, the following error comes.
1:57:14.781 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel online is linked although the handler was already disposed.
21:57:14.782 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel last-updated is linked although the handler was already disposed.
21:57:14.783 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel rssi is linked although the handler was already disposed.
21:57:14.784 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel tx-power is linked although the handler was already disposed.
21:57:14.784 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel estimated-distance is linked although the handler was already disposed.
21:57:14.785 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel adapter is linked although the handler was already disposed.
21:57:14.785 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericBluetoothDeviceHandler of thing bluetooth:generic:A483E765CAD5 tried checking if channel location is linked although the handler was already disposed.
21:57:14.787 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘bluetooth:generic:A483E765CAD5’ changed from UNINITIALIZED to INITIALIZING
21:57:14.820 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘bluetooth:generic:A483E765CAD5’ has been updated.
21:57:14.823 [WARN ] [e.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
21:57:14.824 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘bluetooth:generic:A483E765CAD5’ changed from INITIALIZING to ONLINE
21:57:14.825 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.initialize()’ on ‘org.sputnikdev.esh.binding.bluetooth.handler.GenericBluetoothDeviceHandler@57806bfa’: thingRegistry
java.lang.NoSuchFieldError: thingRegistry
at org.sputnikdev.esh.binding.bluetooth.handler.GenericBluetoothDeviceHandler.access$000(GenericBluetoothDeviceHandler.java:29) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.GenericBluetoothDeviceHandler$7.getValue(GenericBluetoothDeviceHandler.java:95) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.GenericBluetoothDeviceHandler$7.getValue(GenericBluetoothDeviceHandler.java:90) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.SingleChannelHandler.init(SingleChannelHandler.java:119) ~[?:?]
at java.util.concurrent.ConcurrentHashMap$KeySetView.forEach(ConcurrentHashMap.java:4649) ~[?:1.8.0_232]
at org.sputnikdev.esh.binding.bluetooth.handler.BluetoothHandler.initChannelHandlers(BluetoothHandler.java:240) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.BluetoothHandler.lambda$initialize$0(BluetoothHandler.java:60) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.CompletableFutureService.submit(CompletableFutureService.java:35) ~[?:?]
at org.sputnikdev.bluetooth.manager.impl.CombinedDeviceGovernorImpl.when(CombinedDeviceGovernorImpl.java:224) ~[?:?]
at org.sputnikdev.bluetooth.manager.BluetoothGovernor.whenReady(BluetoothGovernor.java:135) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.BluetoothHandler.initialize(BluetoothHandler.java:59) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.handler.GenericBluetoothDeviceHandler.initialize(GenericBluetoothDeviceHandler.java:140) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_232]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_232]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
21:57:14.836 [ERROR] [.core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ‘bluetooth:generic:A483E765CAD5’: thingRegistry
21:57:14.836 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘bluetooth:generic:A483E765CAD5’ changed from ONLINE to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): thingRegistry
I think the NoSuchFieldError is generated because of the version conflict of maven bundle, as far as what I googled. How can I solve it and what is the real reason for this problem?
