Hi, I am quite new to Openhab2, so today I was trying to use the persistence to show a chart in the basic ui.
First of all I always get the warning: [el.core.internal.ModelRepositoryImpl] - Configuration model 'rrd4j.persist' has errors, therefore ignoring it: [1,1]: mismatched input '<EOF>' expecting 'Strategies'
But there is definetlly no space or something, what could produce this issue. I am using the Visual Studio Code Editor.
The next issue is that I couldnt get a right working chart out of my programming. There is a chart, but there are no values inside the chart. Sometimes there is a value in the basic ui for the item “Leistung”, but after a while it is just not refreshing any more and stays always on a random fixed value. By the way all of the items in the group are number items. Maybe someone could give me a small hint. Thanks very much in advance for your help.
Group gTemp "Temperaturverlauf"
Number Temperatur_EG "aktuelle Temperatur [%.1f °C]" <temperature> (gTemp) {channel="homematic:HmIP-WTH-2:OEQ0310424:000A9709AEEE76:1#ACTUAL_TEMPERATURE"}
Number Temperatur_Kinderzimmer_Ist "aktuelle Temperatur [%.1f °C]" <temperature> (gTemp) {channel="homematic:HmIP-eTRV-2:OEQ0310424:000A18A99431E2:1#ACTUAL_TEMPERATURE"}
“When charting a group of item, make sure that every label is unique. If the label contains spaces, the first word of the label must be unique. Identical labels result in an empty chart.”
Your labels are are virtually identical!
In this case let’s check from the root.
Can you show charts of a single item? Another test would be to check if there are entries in the database at all. You can check that using the REST API.
