For some weeks I am trying to get 433 MHz outlets to work with my Raspberry Pi and ultimately openHAB. I started tinkering with Brennenstuhl outlets but quickly realized that I cannot use those very effortless, since they are utilizing generated codes that I wasn’t able to decode.
I then went and bought ELRO AB440 compatible outlets with DIP switches. I am able to read the commands sent by the remote and was able to send commands via 433Utils. I was able to verify the codes I’m sending with the receiver running. The decimal code is the same when I send it with the remote and with the send tool from the raspberry. Also this verifies a working tx module.
The outlets are switching on and off when I’m using the ELRO remote from the set, but I cannot seem to switch them with the Raspberry. Distance is not an issue, since i placed the outlet several centimeters from the tx module to verify this.
Any ideas to get this working?
