Dear all
I’ve made several attempts to install the Keba addon:
Installation via PaperUI: A created thing remains Uninitialized.
Due to some posts in the forum I have made an binding upgrade to the last snapshot 2.3. Now the Keba thing reached the status Online, but I get no values.
Deinstallation and direct installation via Karaf. Createt Thing (via PaperUI) goes online but again no data.
According to the logfile, the wallbox does not seem to answer, ping timeout.
2018-04-09 21:39:16.107 [INFO ] [ng.keba.handler.KeContactTransceiver] - Listening for incoming data on /0:0:0:0:0:0:0:0:7090
2018-04-09 21:39:16.116 [DEBUG] [ng.keba.handler.KeContactTransceiver] - Establishing the connection to the KEBA KeContact ‘keba:kecontact:e505c036’
2018-04-09 21:39:19.133 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3004’ milliseconds
2018-04-09 21:39:19.168 [DEBUG] [ng.keba.handler.KeContactTransceiver] - Stopping the the KEBA KeContact transceiver
2018-04-09 21:39:37.181 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3004’ milliseconds
2018-04-09 21:39:55.188 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3004’ milliseconds
I can ping the box but without any Problems. By using Packet Sender I get answers from the Wallbox. So I think it is not the Box. All my other addons work very well.
I have no idea what I’m doing wrong or what I can do. Doese anyone have an idea?
Does nobody have an idea? I have now installed Openhab 2.3 and the Keba Binding in version 2.3 from 09.04.2018 on a second Raspi. In created a reduced sitemap which contains only the Keba wallbox. The result is the same as above - no data in the frontend. The logfile says:
2018-04-14 12:58:52.397 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Keba.items’
2018-04-14 12:58:55.777 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-04-14 12:58:57.387 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘Keba.sitemap’
2018-04-14 12:59:00.023 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.50:8080
2018-04-14 12:59:00.116 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.50:8443
2018-04-14 12:59:00.505 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-04-14 12:59:01.028 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-04-14 12:59:01.322 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-04-14 12:59:10.558 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-04-14 13:00:57.471 [DEBUG] [org.openhab.binding.keba ] - BundleEvent INSTALLED - org.openhab.binding.keba
2018-04-14 13:00:57.554 [DEBUG] [org.openhab.binding.keba ] - BundleEvent RESOLVED - org.openhab.binding.keba
2018-04-14 13:00:57.562 [DEBUG] [org.openhab.binding.keba ] - BundleEvent [unknown:512] - org.openhab.binding.keba
2018-04-14 13:00:57.573 [DEBUG] [org.openhab.binding.keba ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=316, service.bundleid=230, service.scope=bundle, component.name=org.openhab.binding.keba.internal.KebaHandlerFactory, component.id=192} - org.openhab.binding.keba
2018-04-14 13:00:57.584 [DEBUG] [org.openhab.binding.keba ] - BundleEvent STARTING - org.openhab.binding.keba
2018-04-14 13:00:57.588 [DEBUG] [org.openhab.binding.keba ] - BundleEvent STARTED - org.openhab.binding.keba
2018-04-14 13:01:53.065 [TRACE] [ng.keba.handler.KeContactTransceiver] - There are now 1 KEBA KeContact handlers registered with the transceiver
2018-04-14 13:01:53.068 [DEBUG] [ng.keba.handler.KeContactTransceiver] - Starting the the KEBA KeContact transceiver
2018-04-14 13:01:53.076 [INFO ] [ng.keba.handler.KeContactTransceiver] - Listening for incoming data on /0:0:0:0:0:0:0:0:7090
2018-04-14 13:01:53.081 [DEBUG] [ng.keba.handler.KeContactTransceiver] - Establishing the connection to the KEBA KeContact ‘keba:kecontact:afee4fd8’
2018-04-14 13:01:53.083 [TRACE] [ng.keba.handler.KeContactTransceiver] - Connecting the channel for /192.168.178.47:7090
2018-04-14 13:01:56.100 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3004’ milliseconds
2018-04-14 13:01:56.103 [TRACE] [ng.keba.handler.KeContactTransceiver] - There are now 0 KEBA KeContact handlers registered with the transceiver
2018-04-14 13:01:56.109 [DEBUG] [ng.keba.handler.KeContactTransceiver] - Stopping the the KEBA KeContact transceiver
2018-04-14 13:02:12.641 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3004’ milliseconds
2018-04-14 13:02:12.644 [TRACE] [ng.keba.handler.KeContactTransceiver] - There are now 0 KEBA KeContact handlers registered with the transceiver
2018-04-14 13:02:14.121 [DEBUG] [inding.keba.handler.KeContactHandler] - Ping timed out after ‘3003’ milliseconds
2018-04-14 13:02:14.125 [TRACE] [ng.keba.handler.KeContactTransceiver] - There are now 0 KEBA KeContact handlers registered with the transceiver
