log commands (at least from DSL) will always log to org.openhab.core.model.script.<loggername>, where <loggername> is replaced by the first string given in the log command.
I’m not sure if you need to add some configuration to avoid double logging (your log file and openhab.log), but I’m pretty sure you have to set the absolute path as logger name, like this:
Thanks for the help. The message now arrives in my output file.
The message now only appears in this file and not in the openhab.log - thats ok!
But after changing the log4j2.xlm file I had following message at openhab.log. Can I “read over” them or do I have to correct something?
[image]
2024-03-07 15:19:10.834 [ERROR] [t.ide.server.concurrent.WriteRequest] - Error during request:
java.util.concurrent.CompletionException: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.model.script.actions.Log'; a registered resource factory is needed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:332) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1527) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1517) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1519) ~[?:?]
at java.util.concurrent.CompletableFuture.allOf(CompletableFuture.java:2419) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.cancel(RequestManager.java:114) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.runWrite(RequestManager.java:80) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.initialize(LanguageServerImpl.java:235) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$recursiveFindRpcMethods$0(GenericEndpoint.java:65) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.request(GenericEndpoint.java:120) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleRequest(RemoteEndpoint.java:261) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:190) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:194) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:94) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:113) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
Caused by: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.model.script.actions.Log'; a registered resource factory is needed
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:263) ~[?:?]
at org.eclipse.xtext.ide.server.ProjectManager.getResource(ProjectManager.java:181) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.read(WorkspaceManager.java:470) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:454) ~[?:?]
at org.eclipse.xtext.ide.server.findReferences.WorkspaceResourceAccess.readOnly(WorkspaceResourceAccess.java:36) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.doRead(DocumentSymbolService.java:318) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:110) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:96) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$28(LanguageServerImpl.java:633) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:458) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:632) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:620) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$27(LanguageServerImpl.java:611) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$1(ReadRequest.java:66) ~[?:?]
... 5 more
