Hi all,
I’ve tried to read up on the connection problems other people are having with the Razberry Z-wave controller and in a Raspberry Pi mod B+. The log file shows this:
2015-12-15 18:38:38.739 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyAMA0
2015-12-15 18:38:38.769 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
2015-12-15 18:38:38.773 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2015-12-15 18:38:38.869 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2015-12-15 18:38:38.871 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2015-12-15 18:38:38.872 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
2015-12-15 18:38:38.970 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
2015-12-15 18:38:43.775 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
Now, this is my device:
$ ls -al /dev/ttyAMA0
crwxrwxrwx 1 root dialout 204, 64 Dec 15 18:10 /dev/ttyAMA0
and I have added information on the port both in the startup script:
JAVA_ARGS_DEFAULT="-Dosgi.clean=true \
-Declipse.ignoreApp=true \
-Dosgi.noShutdown=true \
-Djetty.port=${HTTP_PORT} \
-Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg" \
-Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations" \
-Dopenhab.logdir="${OPENHAB_LOG_DIR}" \
-Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
-Djetty.home="${OPENHAB_DIR}" \
-Djetty.port.ssl=${HTTPS_PORT} \
-Djetty.config="${OPENHAB_CONF_DIR}/jetty" \
-Djetty.logs="${OPENHAB_LOG_DIR}" \
-Djetty.rundir="${OPENHAB_DIR}" \
-Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons" \
-Dfelix.fileinstall.filter=.*\\.jar \
-Djava.library.path="${OPENHAB_DIR}/lib" \
-Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf" \
-Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties" \
-Dequinox.ds.block_timeout=240000 \
-Dequinox.scr.waitTimeOnBlock=60000 \
-Dfelix.fileinstall.active.level=4 \
-Djava.awt.headless=true \
-jar ${LAUNCHER} \
-configuration ${OPENHAB_WORKSPACE_DIR} \
-data ${OPENHAB_WORKSPACE_DIR} \
-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 \
-console ${TELNET_PORT}"
and in the openhab.cfg file:
################################ Z-Wave Binding ######################################
zwave:port=/dev/ttyAMA0
zwave:healtime=2
I’m running out of things to try now. Please advice.
Fredrik
