*Hi I have probles with rule which has the task of starting the recuperator’s run.The course is to change from time and humidity.
I have info in log :``2018-12-02 20:04:46.864 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Wilgotnosc & predkosc’: An error occurred during the script execution: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid: (eProxyURI: predkosc.rules#|::0.2.2.2.0.0.1.0.0::0::/1)
I do not know why.
My rule
import java.lang.Math
var boolean autoChangeInProgress = false
rule "Reczna interwencja"
Item Lueftung_Fan_Level changed
if( autoChangeInProgress ){
else{
postUpdate(Lueftung_Auto_Mode,0)
rule "Predkosc"
Item Lueftung_Auto_Mode changed
or
Time cron "0 0/1 * * * ?"
if( (Lueftung_Auto_Mode.state as DecimalType) == 1 ){
var Number day = now.getDayOfWeek
var Number hour = now.getHourOfDay
var Number minute = now.getMinuteOfHour
var boolean isNight = false
// Freitag
if( day == 5 ){
if( hour < 7 || (hour >= 23 && minute >=30) ) isNight = true
// Samstag
else if( day == 6 ){
if( hour < 9 || (hour >= 23 && minute >=30) ) isNight = true
// Sonntag
else if( day == 7 ){
if( hour < 9 || (hour >= 22 && minute >=30) || hour >= 23 ) isNight = true
else{
if( hour < 7 || (hour >= 22 && minute >=30) || hour >= 23 ) isNight = true
var Number currentLevel = (Lueftung_Fan_Level.state as DecimalType)
var Number newLevel = 2
// roznica temperatur
if( !isNight ){
var Number raumTemperatur = (Lueftung_Ablufttemperatur.state as DecimalType)
var Number aussenTemperatur = (Lueftung_Aussenlufttemperatur.state as DecimalType)
var Number zielTemperatur = (Lueftung_Komfortemperatur.state as DecimalType)
if(
raumTemperatur >= zielTemperatur
aussenTemperatur >= raumTemperatur
newLevel = 1
else if(
raumTemperatur >= zielTemperatur - 1
aussenTemperatur >= raumTemperatur - 1
currentLevel == 1
newLevel = 1
if( newLevel != currentLevel ){
autoChangeInProgress=true
sendCommand(Lueftung_Fan_Level,newLevel)
rule "Wilgotnosc & predkosc"
Item wilg_lazienka changed
or
if ((wilg_lazienka.state > 70)) {
Override = false
sendCommand(Lueftung_Fan_Level, 3)
else if (((Override == false) && (wilg_lazienka.state < 58))) {
sendCommand(Lueftung_Fan_Level, 1)
endyour code goes here
