Hi all
I’m struggling again with some simple rules. For this example, I’m working with integer numbers only.
I have the following defined at the top of my rules file
var Number m_main_missing
var Number m_main_wanted
In the item file I have
Number watering_main_today “Time running [%d]” (gWatering)
Now I want to simply calculate the vlaue for m_main_missing, I’m trying
m_main_missing = (m_main_wanted-(watering_main_today.state as Number))
But this gives me the following error:
Error during the execution of rule water Calculate time wanted: java.lang.Number
I still don’t really get the whole casting of int, Integer, DecimalType, and and…
Thanks for any clearifications
Try this one:
if(watering_main_today.state instanceof DecimalType) {
m_main_missing = m_main_wanted - (watering_main_today.state as DecimalType).intValue
Of course, m_main_wanted has to be a valid Integer, too.
If I try it like that, m_main_missing is “null”.
Inserted a logInfo inside the if that is never executed.
So…
What is the log of
logInfo ("w_Calculate_time","watering_main_today: {}",watering_main_today.state)
Ah, that’s the right question!
Turns out, it’s
2017-07-29 17:29:00.017 [INFO ] [rthome.model.script.w_Calculate_time] - watering_main_today: NULL
So I had to insert the following at the beginning of the rule
if(watering_main_today.state == NULL) watering_main_today.postUpdate(0);
Thanks a lot for the quick help!
One question: Why the if instanceof DecimalType ? If I defined the Item as Number, can I not assume that it’s always a DecimalType? Or is the check exactly for NULL values ?
Afaik Number is parent of Decimal, and you can cast every valid Number to DecimalType.
Please keep in mind, that unlike jva you don’t need to use a ; at the and of line.
openHAB rules engine uses a DSL based on xtend, so there might be similarities but also differences to java.
Thanks for the explanation. A sure, don’t know how the ; slipped in there. Old habits I guess
habits
