Problems with the IpCamera Binding
After my Synology system crashed as a result of a power failure, I have now been able to restore (almost) everything. However, one problem still remains:
I can’t get the IpCamera Binding Onvif (but also alternatively RTSP/HTTP) in Openhab 3.4.2 / Docker for a Reolink RLC-511WA to work. However, it worked before in an earlier version.
After a successful setup, the image item should be at the URL
`http://192.168.xx.xxx:8080/ipcamera/34c ... camera.jpg`
For example, deliver an image or the item with the MJPEG URL
`http://192.168.xx.xxx:8080/ipcamera/34c ... camera.mjpeg`
a stream. In both cases nothing is displayed. The camera delivers over
rtsp://192.168.xx.xxx:554/h264Preview_01_main
in Motioneye a very good stream.
I’ve come to the end of my ideas, so I’ll ask the experts: does anyone have a suggestion for me?
What do the logs show in trace level? It should log that the http request was received and then provide details as to when it stops working. Does the port 8080 work at providing the main UI or is docker blocking the http server?
Sorry, but what is the Trace level protocol in OH3?
There could be several reasons why the IpCamera Binding Onvif is not working with your Reolink RLC-511WA camera in Openhab 3.4.2 / Docker. Here are some suggestions to try:
  1. Check the network settings: Make sure that your camera is connected to the network and that it has the correct IP address. Also, check the network settings in Openhab to ensure that the IP address and port number are correct.
  2. Check the credentials: Make sure that you have entered the correct login credentials for your camera in the binding configuration.
  3. Check the binding configuration: Double-check the binding configuration to ensure that all the settings are correct. You can try deleting the camera from the binding and adding it again.
  4. Check the camera compatibility: Make sure that your camera is compatible with the IpCamera Binding Onvif. Some cameras may not work with this binding, so check the compatibility list to ensure that your camera is supported.
  5. Check the firewall: Make sure that the necessary ports are open on your firewall to allow communication between the camera and Openhab.
  6. Check the camera firmware: Check if there is any firmware update available for your camera. Sometimes, updating the camera firmware can fix compatibility issues with the binding.
  7. Check the logs: Check the logs in Openhab to see if there are any error messages related to the IpCamera Binding Onvif. This may help you to identify the issue.
Very start of the bindings docs cover this…
IP Camera - Bindings | openHAB
Diagnose the issue first with the logs, then we don’t need to guess at the cause and can provide better help knowing more info.
In case you did not know, there is a beta build of the binding that is adding Reolink API support. Doing the docs now to get it merged.
I made the settings for trace and restarted the container. The following messages were created in the Openhab.log, but also a large number with the note “Debug”.
In fact, I’m overwhelmed now and don’t know what these messages are supposed to tell me. Maybe someone knows an advice?
2023-03-29 16:14:06.141 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2023-03-29 16:14:07.237 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>NTP</tt:DateTimeType><tt:DaylightSavings>true</tt:DaylightSavings><tt:TimeZone><tt:TZ>GMT+8DST</tt:TZ></tt:TimeZone></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:07.245 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2023-03-29 16:14:07.601 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">S+lfT6gksSQ7cYvIOjHyBBZahpQ=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTQyMzY2ODA4Mg==</wsse:Nonce><wsu:Created>2023-03-29T14:14:07.255Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Device><tt:XAddr>http://192.168.1.7:8000/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:ZeroConfiguration>false</tt:ZeroConfiguration><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS></tt:Network><tt:System><tt:DiscoveryResolve>true</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>false</tt:SystemLogging><tt:FirmwareUpgrade>false</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>21</tt:Major><tt:Minor>6</tt:Minor></tt:SupportedVersions></tt:System><tt:IO></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.1.7:8000/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.1.7:8000/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.1.7:8000/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>false</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP><tt:Extension></tt:Extension></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>10</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:PTZ><tt:XAddr>http://192.168.1.7:8000/onvif/ptz_service</tt:XAddr></tt:PTZ><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.1.7:8000/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>1</tt:AudioSources><tt:AudioOutputs>0</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs></tt:DeviceIO></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:07.664 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetProfiles
2023-03-29 16:14:08.160 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">jAZ17YBIQPFYHqXkrXd58AW1E+I=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">NDEzNjgwOTQ3</wsse:Nonce><wsu:Created>2023-03-29T14:14:07.666Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetProfilesResponse><trt:Profiles token="000" fixed="true"><tt:Name>Profile000_MainStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="000"><tt:Name>VideoE_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>2048</tt:Width><tt:Height>1536</tt:Height></tt:Resolution><tt:Quality>0</tt:Quality><tt:RateControl><tt:FrameRateLimit>20</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>4096</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>40</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioE_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>16</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>238.255.255.255</tt:IPv4Address></tt:Address><tt:Port>25320</tt:Port><tt:TTL>60</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT0S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>VideoA_000</tt:Name><tt:UseCount>1</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Type="tt:CellMotionEngine" Name="MyCellMotionModule"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="0"></tt:SimpleItem><tt:ElementItem Name="Layout"><tt:CellLayout Columns="64" Rows="48"><tt:Transformation><tt:Translate x="-1.000000" y="-1.000000"/><tt:Scale x="0.000977" y="0.001302"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Type="CellMotionDetector" Name="MyMotionDetectorRule"><tt:Parameters><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="Av///PwAAj////wAAw///8D9AAMD///w/AAC///8+wA="></tt:SimpleItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000"><tt:Name>Metadata_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>true</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles><trt:Profiles token="001" fixed="true"><tt:Name>Profile001_SubStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"></tt:Bounds></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioS_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="001"><tt:Name>VideoE_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>480</tt:Height></tt:Resolution><tt:Quality>2</tt:Quality><tt:RateControl><tt:FrameRateLimit>10</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>256</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>40</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>239.0.1.0</tt:IPv4Address></tt:Address><tt:Port>4000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT10S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioE_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>16</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>238.255.255.255</tt:IPv4Address></tt:Address><tt:Port>25320</tt:Port><tt:TTL>60</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT0S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="001"><tt:Name>VideoA_001</tt:Name><tt:UseCount>1</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Type="tt:CellMotionEngine" Name="MyCellMotionModule"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="0"></tt:SimpleItem><tt:ElementItem Name="Layout"><tt:CellLayout Columns="64" Rows="48"><tt:Transformation><tt:Translate x="-1.000000" y="-1.000000"/><tt:Scale x="0.000977" y="0.001302"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Type="CellMotionDetector" Name="MyMotionDetectorRule"><tt:Parameters><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="100"></tt:SimpleItem><tt:SimpleItem Name="AlarmOnDelay" Value="Av///PwAAj////wAAw///8D9AAMD///w/AAC///8+wA="></tt:SimpleItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000"><tt:Name>Metadata_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>true</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles></trt:GetProfilesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.170 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:000
2023-03-29 16:14:08.171 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:001
2023-03-29 16:14:08.192 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSnapshotUri
2023-03-29 16:14:08.195 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStreamUri
2023-03-29 16:14:08.206 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetNodes
2023-03-29 16:14:08.208 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetEventProperties
2023-03-29 16:14:08.211 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetServiceCapabilities
2023-03-29 16:14:08.328 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">JG5lHoylsXoh2moD1AHrcP0tnzQ=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE5OTc5NDc1NTQ=</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.209Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:GetEventPropertiesResponse><tev:TopicNamespaceLocation>http://www.onvif.org/onvif/ver10/topics/topicns.xml</tev:TopicNamespaceLocation><wsnt:FixedTopicSet>true</wsnt:FixedTopicSet><wstop:TopicSet><tns1:VideoSource wstop:topic="false"><MotionAlarm wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken"/></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xsd:boolean"/></tt:Data></tt:MessageDescription></MotionAlarm><ImageTooDark wstop:topic="false"><ImagingService wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken" /></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xsd:boolean" /></tt:Data></tt:MessageDescription></ImagingService></ImageTooDark></tns1:VideoSource><tns1:Media wstop:topic="false"><ProfileChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Data><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken" /></tt:Data></tt:MessageDescription></ProfileChanged><ConfigurationChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Source><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken" /></tt:Source><tt:Data><tt:SimpleItemDescription Name="Type" Type="xsd:string" /></tt:Data></tt:MessageDescription></ConfigurationChanged></tns1:Media><tns1:RuleEngine wstop:topic="true"><CellMotionDetector wstop:topic="true"><Motion wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="VideoSourceConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="VideoAnalyticsConfigurationToken" Type="tt:ReferenceToken"/><tt:SimpleItemDescription Name="Rule" Type="xsd:string"/></tt:Source><tt:Data><tt:SimpleItemDescription Name="IsMotion" Type="xsd:boolean"/></tt:Data></tt:MessageDescription></Motion></CellMotionDetector></tns1:RuleEngine></wstop:TopicSet><wsnt:TopicExpressionDialect>http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet</wsnt:TopicExpressionDialect><wsnt:TopicExpressionDialect>http://docs.oasis-open.org/wsn/t-1/TopicExpression/Concrete</wsnt:TopicExpressionDialect><tev:MessageContentFilterDialect>http://www.onvif.org/ver10/tev/messageContentFilter/ItemFilter</tev:MessageContentFilterDialect><tev:MessageContentSchemaLocation>http://www.onvif.org/onvif/ver10/schema/onvif.xsd</tev:MessageContentSchemaLocation></tev:GetEventPropertiesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.329 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:CreatePullPointSubscription
2023-03-29 16:14:08.476 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">RpFQ8/C1CgO/r/wjRQ41Dpia1N0=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTg2NjQxNDIyOQ==</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.196Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://192.168.1.7:554/</tt:Uri><tt:InvalidAfterConnect>false</tt:InvalidAfterConnect><tt:InvalidAfterReboot>false</tt:InvalidAfterReboot><tt:Timeout>PT10S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.500 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">8uDMaRF4Q87XYhstSF+yklOKZog=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTkzMTg5NDgyMg==</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.207Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetNodesResponse><tptz:PTZNode token="000"><tt:Name>Node_000</tt:Name><tt:SupportedPTZSpaces><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:SupportedPTZSpaces><tt:MaximumNumberOfPresets>0</tt:MaximumNumberOfPresets><tt:HomeSupported>false</tt:HomeSupported></tptz:PTZNode></tptz:GetNodesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.501 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStatus
2023-03-29 16:14:08.515 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurations
2023-03-29 16:14:08.521 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="1">http://192.168.1.7:8000/onvif/event_service</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">GkS/7A4LAKTjZ31ucuZwNCmaILc=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MzA4OTYwMjI1</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.349Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:CreatePullPointSubscriptionResponse><tev:SubscriptionReference><wsa5:Address>http://192.168.1.7:8000/onvif/PullSubManager?Idx=25639722</wsa5:Address></tev:SubscriptionReference><wsnt:CurrentTime>2023-03-29T14:14:08Z</wsnt:CurrentTime><wsnt:TerminationTime>2023-03-29T14:24:08Z</wsnt:TerminationTime></tev:CreatePullPointSubscriptionResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.534 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2023-03-29 16:14:08.577 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Body><SOAP-ENV:Fault><SOAP-ENV:Code><SOAP-ENV:Value>SOAP-ENV:Sender</SOAP-ENV:Value></SOAP-ENV:Code><SOAP-ENV:Reason><SOAP-ENV:Text xml:lang="en">Method 'GetServiceCapabilities' not implemented: method name or namespace not recognized</SOAP-ENV:Text></SOAP-ENV:Reason></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.621 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">nCBbwD3NlJVjQ3qaNZcBVJkDu3s=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTE4MDQxNzMwMzQ=</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.193Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://192.168.1.7:62480/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT10S</tt:Timeout></trt:MediaUri></trt:GetSnapshotUriResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.628 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">qEZ8hNdU/NJtzSustR407yb7JX0=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">LTEzODY5OTQzMA==</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.513Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>2023-03-29T14:14:08Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.640 [WARN ] [amera.internal.onvif.OnvifConnection] - Binding could not determin the cameras current PTZ location. Not all cameras respond to GetStatus requests.
2023-03-29 16:14:08.693 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">Xp+G44Clemai4B2DIFjMRCk+T30=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">NTQzMTM0Mzcy</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.523Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="000"><tt:Name>PtzConfig000</tt:Name><tt:UseCount>3</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt x="1" y="1" space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace"></tt:PanTilt><tt:Zoom x="1" space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT5S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.694 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2023-03-29 16:14:08.698 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurationOptions
2023-03-29 16:14:08.789 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">/1sF9yjY6zxNacYRXEqkXAIa9t4=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTY1NzY3NjgxNA==</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.708Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:Spaces><tt:PTZTimeout><tt:Min>PT1S</tt:Min><tt:Max>PT10S</tt:Max></tt:PTZTimeout></tptz:PTZConfigurationOptions></tptz:GetConfigurationOptionsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:08.826 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:saml1="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:saml2="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:wsc="http://docs.oasis-open.org/ws-sx/ws-secureconversation/200512" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns1="http://www.onvif.org/ver20/media/wsdl" xmlns:tdn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trc="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tad="http://www.onvif.org/ver20/analytics/wsdl"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>admin</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">bsiTsgkKvMQiKIRSF5K/tpuyEkM=</wsse:Password><wsse:Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">MTM3OTAyMDkxNQ==</wsse:Nonce><wsu:Created>2023-03-29T14:14:08.695Z</wsu:Created></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetPresetsResponse></tptz:GetPresetsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2023-03-29 16:14:10.628 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.7:62480/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0
2023-03-29 16:15:08.194 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Unsubscribe
2023-03-29 16:15:08.212 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2023-03-29 16:15:08.216 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2023-03-29 16:15:12.217 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2023-03-29 16:15:20.222 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2023-03-29 16:15:27.358 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
2023-03-29 16:15:27.359 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2023-03-29 16:15:28.231 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.7:62480/cgi-bin/api.cgi?cmd=onvifSnapPic&amp;channel=0
One more question: how to exit the ‘log:set TRACE org.openhab.binding.ipcamera’ mode? I haven’t found a solution yet and the ‘Openhab.Log’ file is always quite bloated since the call.
documentation located at …
says:
The levels build a hierarchy with ERROR logging critical messages only and DEBUG logging nearly everything. DEBUG combines all logs from weight 100 to 500, while TRACE adds further messages in addition to what DEBUG displays. ALL includes every log level from weight 100 to 600. Setting the log level to DEFAULT will log to the level defined in the package.subpackage (in most cases a binding).
That would mean:
log:set DEFAULT org.openhab.binding.ipcamera
Thank you, @Wolfgang_S. As already written, the matter is new to me. Maybe someone else has an idea and can tell me something about the trace messages.
The logs do not show you trying to open a stream or serve any files so this would point to the network not reaching the binding for some reason like a typo in the url, or your docker is blocking the network traffic. The camera is talking to the binding just fine.
A few weeks ago I performed a Synology update. Perhaps FFMPEG is no longer stable, because there are sometimes glitches with the OpenHAB connection. I would like to import a newer file. But I don’t know where to get a newer version for DSM 7.1.
I found other threads where exactly these issues with Synology DSM 7.1 are addressed. However, I would like to avoid uploading the wrong FFMPEG version.
I’ll keep researching. If anyone else has an idea, please feel free to get in touch.
@Cassy0110
Of course, I have clarified these points beforehand. The camera ran before, using an older Synology DSM version
Best regards
Here is the error message for ffmpeg. The file is there, but something is wrong there. I have no more advice.
2023-03-31 05:36:49.027 [WARN ] [hab.binding.ipcamera.internal.Ffmpeg] - An IO error occured trying to start FFmpeg:Cannot run program "/usr/bin/ffmpeg": error=2, No such file or directory
If you have installed ffmpeg, check where you installed it to and then tell the binding the correct path as it is a config that you can change. It may also be the docker isolating stuff and not allowing access, in this case you need a docker expert to help.
Another question about the error message. I noticed that the line at the point
hab.binding.ipcamera.internal.**F**fmpeg
is misspelled. Doesn’t have to mean it
hab.binding.ipcamera.internal.ffmpeg
and maybe that’s why the message came about?
No it is fine due to Java classes start with a capital. The error is very very clear as to what is wrong.
/usr/bin/ffmpeg
Java can not run the process because it is missing or something is preventing it from running. Docker may be blocking it, and I do not know Docker at all. You will need to figure out why the binding can not see and run ffmpeg on your system. I can not help further and your probably best starting your own thread called something like “How do I get FFmpeg installed correctly inside Docker for ip Cameras”. You will need someone who knows Docker to guide you.
Thank you for your support
