Hi all,
back in March/April and with OH3 I had a fully functioning setup with a CC2531 and multiple IKEA TRADFRI bulbs. This setup stopped working some months ago. Initially I suspected my CC2531 to be broken as the green LED stop working. After waiting some time for updates I bought a new CC2531 (Firmware: Koenkk DEFAULT 20201127) as replacement. Unfortunately the system is still not working.
Here is what I tried:
- Updated my OH3 system to the latest stable version (OH3.1)
- Deleted all old config of the Zigbee binding and reinstalling it
- restarted OH3
- Added the CC2531 as CC2531EMK Coordinator (this part seem to be working, the Thing is shown as “Online” and the LED stays green)
- Tried to add aTRADFRI Bulb as previously (start a scan, 5 x off/an to reset the bulb and select the newly discovered Thing)
I am not sure, if it is even the bulb that is found. Zigbee has discovered as “unknown zigbee device”. I am pretty sure that in the past it was discovered as “TRADFRI bulb GU10 WW 400lm”. Nonetheless I tried installing it. The new Thing is added but stays offline. The system says “Node has not completed discovery”. I found some errors into the same topic:
Unfortunately the problem there is “fixed” by the users going over to zigbee2mqtt. I would like to stay with the zigbee binding. Are there any other steps I could try? I activated logging as described in the docu. As a new user I am not allowed to upload it, but it does not look very interesting.
Best Erik
