Hi There,
I’ve used the holidays for upgrading my slave system to OH2.5.
From now, both bindings accessing usb-devices (Z-Wave and my both SmartMeters) are not working correctly.
Z-Wave Binding is restarting time and time again (106 Occurrences of the “Starting ZWave…” String in one log rotation)
2020-01-02 18:58:26.214 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-02 18:58:28.063 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyACM0’
2020-01-02 18:58:28.312 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2020-01-02 18:58:28.689 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-02 18:58:28.691 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-02 18:58:32.472 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
And both SmartMeters are getting initialized correctly after startup (and deliver values) but after a short time they try to restart and can’t connect to the USB tty
2020-01-02 18:57:25.372 [INFO ] [ding.smartmeter.internal.MeterDevice] - Opening connection to smartmeter:meter:pv
2020-01-02 18:57:25.377 [WARN ] [ding.smartmeter.internal.MeterDevice] - Failed to read: Error at SerialConnector.openConnection: unable to open port /dev/ttyUSB1.. Closing connection and trying again in 2 seconds…; smartmeter:meter:pv
java.io.IOException: Error at SerialConnector.openConnection: unable to open port /dev/ttyUSB1.
Any idea what went wrong and if I can get this fixed without downgrading to 2.4?
Bests
Pascal
