i have just upgraded from #1114 to #1134 snapshot release
my z-wave stick dont be seen in openhab, see screenshot.
i have tried readding the stick, same issue.
how to debug ?
running on ubuntu 17.04 as vm on virtualbox
how to debug ?
Check via karaf console if the serial transport dependency is properly installed:
26 │ Active │ 80 │ 3.12.0.OH │ nrjavaserial
If okay, check via
dmesg -T | grep tty
if your port has changed …
25 │ Active │ 80 │ 3.12.0.OH │ nrjavaserial
is installed
[Thu Dec 14 10:48:33 2017] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
also the port is ok.
any other ideas ?
i go almost thru all daily snapshots, and never had this issue
2017-12-14 10:58:19.658 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.zwave.handler.ZWaveSerialHandler@a25e301': null
at org.openhab.binding.zwave.internal.ZWaveConfigProvider.getThingTypeConfig(ZWaveConfigProvider.java:398) [239:org.openhab.binding.zwave:2.2.0.201712132232]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.initialize(ZWaveControllerHandler.java:95) [239:org.openhab.binding.zwave:2.2.0.201712132232]
at org.openhab.binding.zwave.handler.ZWaveSerialHandler.initialize(ZWaveSerialHandler.java:78) [239:org.openhab.binding.zwave:2.2.0.201712132232]
at sun.reflect.GeneratedMethodAccessor73.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.201712132200]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.201712132200]
2017-12-14 10:58:19.670 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'zwave:serial_zstick:06074ec7': null
i just find these error logs
Check if you have two zwave bindings installed (through karaf bundle:list
If not it is maybe time to clear contents of cache and tmp directories …
it is just one binding
bundle:list | grep Z
256 │ Active │ 80 │ 2.2.0.201712141125 │ ZWave Binding
updated to #1135
cleared tmp & cache folder
same error in logs
2017-12-14 13:13:22.140 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.zwave.handler.ZWaveSerialHandler@2f5e7ef8': null
at org.openhab.binding.zwave.internal.ZWaveConfigProvider.getThingTypeConfig(ZWaveConfigProvider.java:398) [239:org.openhab.binding.zwave:2.2.0.201712141125]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.initialize(ZWaveControllerHandler.java:95) [239:org.openhab.binding.zwave:2.2.0.201712141125]
at org.openhab.binding.zwave.handler.ZWaveSerialHandler.initialize(ZWaveSerialHandler.java:78) [239:org.openhab.binding.zwave:2.2.0.201712141125]
at sun.reflect.GeneratedMethodAccessor87.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.201712141004]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.201712141004]
2017-12-14 13:13:22.141 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'zwave:serial_zstick:06074ec7': null
Hmm, out of ideas, sorry
On #1135 and experiencing the same issue.
i just tried downgrading to latest working snapshot #1114
but same issue
any ideas how to get work again ?
This post helped me a lot
This is what I did:
/tmp/
and /cache/
in openhab2-userdata
zwave
binding from services/addons.cfg
- if you installed it through Paper UI, uninstall it same wayssh openhab@localhost -p 8101
)bundle:install http://www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-2.2.0-SNAPSHOT.jar
to see what’s the ID of our new bundle bundle:start 265
Now everything is back to normal.
did you re add (bind) things or did they appear automatically ?
i have about 160 things, if they will be gone, i need days to reconfig them
so, you switched to the dev/sec version of the Z-Wave binding (removed snapshot zwave) and it works ok on OH2 core Snapshot builds greater than 1134?
No, I’ve rolled back to #1120 and I’ve readded my Z-wave things.
ok
by the way… the link that you referred to (http://www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-2.2.0-SNAPSHOT.jar ) is the dev/sec version from this thread: OH2 Z-Wave refactoring and testing... and SECURITY
that’s different than the “mainstream” snapshot version of the z-wave binding
So: You went back to S1120 OH2.2 core and you are using the dev/sec zwave… correct?
what version is the bundle that you are using?
openHAB 2.2.0~20171209104822-1 (Build #1120)
on RPi3B running openHABian.
Yes, the bundle is from the security thread - that was the only one that worked for me, unlike the mainstream version.
openhab> bundle:list | grep Z
265 │ Active │ 80 │ 2.2.0.201712100924 │ ZWave Binding
is fixed in #1137
