Profiles are great way to reduce rules writing but currently it only support device to device but not item to item. As I am using proxy items, profiles in it’s current support is not helpful to me.
Using item metadata and Jython, I have added profile support that can follow item state, until, I hope, in the future, will be replaced by builtin support.
Some notes:
- This is initial version with only follow profile
- I will probably add more profiles in the future.
- The current version support only single profile, planing to have the ability to define multiple profiles
- The script uses the metadata class (see here)
Item should have the following metadata:
Switch Test_Power { profile="follow" [item="Sonoff_Power"] }
Available follow options:
- item (Mandatory) - The followee (the other item to follow)
- offset (Optional, default 0) - Not supported yet (will be added to Number items in the future)
- forward (Optional, default “command”) - sendCommand (command) or postUpdate (update)
And the Jython script (002_initialize_profiles.py) is:
Init profiles
from personal.metadata import Metadata
from core.log import logging, LOG_PREFIX
from core.triggers import ItemCommandTrigger, ItemStateUpdateTrigger
scriptExtension.importPreset("RuleSimple")
scriptExtension.importPreset("RuleSupport")
# Module logge r
log = logging.getLogger(LOG_PREFIX + ".profiles")
# Total profiles (for debugging)
profiles = 0
This item follow other item state
class followRule(SimpleRule):
type = "follow"
def __init__(self, this, other, offset = None, forward = "command"):
self.name = "Profile: {} follow {}".format(this, other)
self.this = this
self.other = other
self.forward = forward
self.triggers = [
ItemCommandTrigger(other).trigger,
ItemStateUpdateTrigger(other).trigger
def execute(self, module, input):
if self.forward == "command" or self.forward == None:
events.sendCommand(self.this, str(items[self.other]))
elif self.forward == "update":
events.postUpdate(self.this, str(items[self.other]))
else:
log.info("Unsupported forward type: {}".format(self.forward))
Iterate all items and initialize profiles:
- Follow { profile="follow" [item =<name>, offset=<value>, forward=update/command] }
for item in ir.getItems():
m = Metadata(item.name, "profile")
if m.exist() == True:
# Add follow profile
if m.get_value() == followRule.type:
# Profile configuration
other = m.get_configuration_value_for_key("item")
offset = m.get_configuration_value_for_key("offset")
forward = m.get_configuration_value_for_key("forward")
# Validate mandatory parameters
if other != None:
automationManager.addRule(followRule(item.name, other, offset, forward))
profiles += 1
# Unsupported profile
else:
log.info("Profile {} is not supported yet".format(m.get_value()))
log.info("Loaded {} profiles".format(profiles))
Comments are welcome
