OH3, 2 week old install, with a new ecoBee 4 lite.
Perhaps this is by design, but my string ProgramCurrentClimateRef, program#currentClimateRef, is not updating when I perform a climate hold. For example, I can send an “away” hold, and it is accepted as confirmed on the thermostat. However the item ProgramCurrentClimateRef says “home”, the state before the hold.
ProgramCurrentClimateRef will update under non-hold conditions as the thermostat performs it’s programmed schedule. In my case, alternating between “home” and “sleep”.
If this is the expected behavior, then how do I tell what climate is currently active? Is there another channel I haven’t discovered?
My new thermostat is otherwise performing as expected!
In the scenario I tested, I did the following in a rule:
val ecobeeActions = getActions("ecobee","ecobee:thermostat:account:XXXXXXXXXX")
ecobeeActions.setHold("away")
The program#currentClimateRef always seems to contain the current climate ref associated with the schedule, irrespective of whether a hold is in place.
In the event, however, the holdClimateRef does show the climate ref that’s in effect as a result of the hold (assuming the hold was set using a climate ref).
