Running OpenHabian4 + InfluxDB on a Raspberry Pi 4. I am daily fetching electricity spot data from Entso-E, Sometimes Entso-E can be down and then I can’t get control data for my heat pump.
To cope with this situation I mad a rule with manually typed control data for the heat pump that can be run at those situations that Entso_E is down. It works perfectly but is a little bit awkward to use because you have to type in the points array data and run the rule when needed. Then code here below,
influx = require('/etc/openhab/scripts/kotikolo/influx.js');
points = [
{ "datetime": "2024-02-09T22:00:00Z", "value": 0 },
{ "datetime": "2024-02-09T23:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T00:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T01:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T02:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T03:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T04:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T05:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T06:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T07:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T08:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T09:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T10:00:00Z", "value": 1 },
{ "datetime": "2024-02-10T11:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T12:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T13:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T14:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T15:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T16:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T17:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T18:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T19:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T20:00:00Z", "value": 0 },
{ "datetime": "2024-02-10T21:00:00Z", "value": 0 }
influx.writePoints('heatpump_control', points);
In order to make a better approach I made a new rule with preset control data that is run every day just before the Entso-E data fetch is run. If the Entso-E fetch succeeds the this preset data is overwritten by control data based on the electricity spot prices. My problem is that I can’t figure out why the control data created programatically in the points array variable isn’t savet to the InfluxDB. No error messages are shown and if i log the contents of the points array to the console the data is correct. Here is the rule code,
// Set the date to todays date and time 22:00:00
date = new Date();
date.setDate(date.getDate() + 1);
date.setHours(1);
date.setMinutes(0);
date.setSeconds(0);
date.setMilliseconds(0);
points = [];
createPointsArrayData();
// Write the actual control data to the points array
function createPointsArrayData() {
for (let h = -2; h < 22; h++) {
startString = '{ "datetime": "';
if (h < -1) {
endString = '", "value": 0 }'
} else if (h > -2 && h < 6) {
endString = '", "value": 1 }'
} else if ((h >= 6 && h < 21)) {
} else {
newHour = 2 + h;
d = new Date(date.setHours(newHour)).toISOString().replace(".000Z", "Z");
newString = startString + d + endString;
let data = newString;
points.push(data);
The messages that comes from the influx.js script are exactly the same with both rules,
- influx.js: Preparing to write 24 points to the database for heatpump_control
- influx.js: Points successfully saved for measurement heatpump_control
It is a total mystery to me why both rules seems to work correctly only the first with hardcoded points array data actually saves data to the InfluxDB.
