Recently I tried to move my setup from a Debian Direct Setup (HW: 2010 MacMini) to an LXC Container on a new Intel NUC with Proxmox 8.1.5 installed.
Backup & Restore of OH Config did a great job, all Things are Online.
But after about 5 Minutes OpenHAB (4.1.2) did not receive any Messages from the KNX Router anymore. I can send messages to KNX like Rollershutter, but there are no upates from the KNX Bus like temperatures, button presses, pesence detection.
Other Bindings seem to work correct. The setup has 40 Bindings, 185 Things, 1000 items, …
KNX is the backbone in my house, if KNX and openHAB is not working there is no light because openHAB does the translation to DMX.
If I do a PAUSE on the KNX Router Thing, it starts working again for aprox. 5 Minutes.
I also did a reinstall of the container and OpneHAB with only the KNX Router Thing and 1 KNX Device. Same behavior. KNX Binding on DEBUG Log does not show anything suspicious. Just no new messages…
Maybe @Udo_Hartmann has a tip for me, because I read in some older threads that you are using a similar setup with proxmox…
UID: knx:ip:00c5-01022df6
label: KNX / IP-Router
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
autoReconnectPeriod: 60
localIp: 192.168.20.11
type: ROUTER
localSourceAddr: 1.1.1
readingPause: 50
portNumber: 3671
responseTimeout: 10
UID: knx:device:00c5-01022df6:e9cf2a4023
label: Taster Wohnen
thingTypeUID: knx:device
configuration:
pingInterval: 300
readInterval: 0
fetch: false
bridgeUID: knx:ip:00c5-01022df6
channels:
- id: bewegung_essen
channelTypeUID: knx:switch
label: Bewegung Wohnen
description: null
configuration:
ga: 1.001:6/2/5
- id: bewegung_wohnen
label: Bewegung Essen
description: null
configuration:
ga: 1.001:6/2/0
- id: temperatur
channelTypeUID: knx:number
label: Temperatur Wohnen
description: Ein Kanal zur Verwaltung einer generischen Gruppenadressen mit
einem DPT (Datenpunkttyp) kompatibel mit Number Items
configuration:
ga: 9.001:<4/2/0
- id: helligkeit_essen
label: Helligkeit Wohnen
configuration:
ga: 5.001:<6/2/2
- id: helligkeit_wohnen
label: Helligkeit Essen
configuration:
ga: 5.001:<6/2/2
