I have a problem with a rule definition
when the PIR recive a state change, it trigger these rule:
// Imports
import org.eclipse.smarthome.core.library.types.*
import org.eclipse.smarthome.core.persistence.*
import org.eclipse.smarthome.model.script.actions.*
import org.eclipse.smarthome.core.types.*
import org.eclipse.smarthome.core.items.*
import org.joda.time.*
import java.util.regex.Matcher
import java.util.regex.Pattern
import java.util.List
// Global Variables
var Timer LIFX_Timer_1 = null
rule "PIR_Soggiorno"
Item PIR1_soggiorno changed
or
Item PIR2_soggiorno changed
if (PIR1_soggiorno.state == ON || PIR2_soggiorno.state == ON) {
if (LIFX_Timer_1 == null) {
if ((now.isAfter(now.withTimeAtStartOfDay.plusHours(21)) || now.isBefore(now.withTimeAtStartOfDay.plusHours(7))) && LIFX1_Int_Soggiorno_Accendi.state == OFF && Luminosita_Int_Soggiorno.state < 10) {
sendCommand(LIFX1_Int_Soggiorno_Dimmer, 25)
LIFX_Timer_1 = createTimer(now.plusSeconds(30)) [|
LIFX_Timer_1.cancel
LIFX_Timer_1 = null
sendCommand(LIFX1_Int_Soggiorno_Accendi, OFF)
else {
LIFX_Timer_1.reschedule(now.plusSeconds(30))
But on the logs file i have these error every time the PIR send a state change
[ERROR] [.script.engine.ScriptExecutionThread] - Rule 'PIR_Soggiorno': cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
Can some one help me ?
I’m confused because the rule works
