QbusKoen
(Koen Schockert)
#1
Can’t seem to download the public key for installation.
Following installation guide for Debian:
This command:
curl -fsSL "https://openhab.jfrog.io/artifactory/api/gpg/key/public" | gpg --dearmor > openhab.gpg
Gives a timeout::
curl: (22) The requested URL returned error: 504 Gateway Time-out
gpg: no valid OpenPGP data found.
QbusKoen
(Koen Schockert)
#2
I’m confused.
I updated openHAB this morning, from 3.2.0 to 3.3.0.
Problem is that none of my addons will install:
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt, openhab-binding-sensibo, openhab-persistence-rrd4j, openhab-ui-basic, openhab-binding-nest, openhab-binding-squeezebox, openhab-binding-sonos, openhab-ui-habpanel': Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.basic/3.3.0
Is this a problem on my side? Or a problem with the server that provides the addons?
If I do a check on the addon server:
The server seems to be down.
QbusKoen
(Koen Schockert)
#3
OK, must have been a server issue.
Bindings are installed now and i can add the public key.
