Hi Gens,
Im new in the OpenHab system, can some one can say me is it any possibility type message and publish it from UI interfaces such as Android app or Web app, i want send to my arduino command which i add manually ?
Thanks in advance .
Hi Gens,
Thanks in advance .
If you use HABPanel this
could do.
Thanks that help me )) now i need find some script to send POST request by pressing button
Using my HABPanel example the text gets send to an item. Using a rule on the changed event of that item would be a way. Search the forum for a POST example in a rule to put it together.
