Dear community,
After having configured the PulseAudio binding with an RTP sink, I realize the following exception thrown upon OpenHAB startup:
2022-03-30 10:21:05.189 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:bridge:local' changed from UNINITIALIZED to INITIALIZING
2022-03-30 10:21:05.204 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:sink:local:rtp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2022-03-30 10:21:06.217 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:bridge:local' changed from INITIALIZING to ONLINE
2022-03-30 10:21:06.218 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:sink:local:rtp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2022-03-30 10:21:06.218 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:sink:local:rtp' changed from INITIALIZING to OFFLINE
2022-03-30 10:21:06.218 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.pulseaudio.internal.handler.PulseaudioHandler@a8e1490': class java.lang.String cannot be cast to class java.lang.Boolean (java.lang.String and java.lang.Boolean are in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class java.lang.String cannot be cast to class java.lang.Boolean (java.lang.String and java.lang.Boolean are in module java.base of loader 'bootstrap')
at org.openhab.binding.pulseaudio.internal.handler.PulseaudioHandler.initialize(PulseaudioHandler.java:106) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor80.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2022-03-30 10:21:06.220 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'pulseaudio:sink:local:rtp': class java.lang.String cannot be cast to class java.lang.Boolean (java.lang.String and java.lang.Boolean are in module java.base of loader 'bootstrap')
2022-03-30 10:21:06.223 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:sink:local:rtp' changed from OFFLINE to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): class java.lang.String cannot be cast to class java.lang.Boolean (java.lang.String and java.lang.Boolean are in module java.base of loader 'bootstrap')
2022-03-30 10:21:06.223 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'pulseaudio:sink:local:rtp' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): class java.lang.String cannot be cast to class java.lang.Boolean (java.lang.String and java.lang.Boolean are in module java.base of loader 'bootstrap') to ONLINE
2022-03-30 10:21:06.224 [INFO ] [rnal.handler.PulseaudioBridgeHandler] - Established connection to Pulseaudio server on Host '127.0.0.1':'4712'.
I assume that, at the end, the sink is properly initialized as it goes online. Nevertheless, I wonder what the cause of this exception is or whether I need to adjust my system? Any guidance is appreciated as how to cope with this exception.
Best regards,
Peter
