Push notification stops working since a couple of days ago
The icon is actually not supported on iOS (i need to note that in the docs). This is a Apple/IOS restriction. Attaching an image however will provide a small thumbnail on the message, i have contemplated maybe using this as a hack to show icons, but honestly its not actually come up much over the last few years, so i doubt i will look into it much as there are a lot of other improvements to be made.
I see, thanks for replying!
Hi @somy
Here is the link to answer to your system starting question:
I hope that helps!
Thanks for the link, I think I also saw this however:
“Start levels less than 40 are not available as triggers because the rule engine needs to start up first before it can execute any rules. Please keep in mind that rule engines provided by separately installed automation add-ons might not start executing rules until after start level 100 is reached”
So basically it will only trigger when start level is 50, I assume you mark system starting, and then when it reaches 100, you mark system starting completes, right? Thanks
