I would like to connect my PV installation with energy storage to Openhab. What 10kW hibrig inverter would you recommend that can be connected to OpenHab?
Have a look on the available bindings.
Minimum would be in my opinion access via Modbus.
So you could use the Modbus binding to pull data.
That should not be a relevant factor in deciding for a PV vendor.
Choose your 2 or 3 favorites wisely based on criteria such as flexibility, availability, price etc, then come back and cross-check if OH can handle them.
Will be deye SUN-10K-SG04LP3
