Just had a go installing it on my Windows system.
However, getting this in the log:
[2021-08-15 21:08:28,521] [ HABApp] ERROR | Error Invalid value for ContactItem: OFF in on_sse_event:
[2021-08-15 21:08:28,521] [ HABApp] ERROR | File "F:\Apps\habapp\lib\site-packages\HABApp\core\wrapper.py", line 130, in f
[2021-08-15 21:08:28,521] [ HABApp] ERROR | return func(*args, **kwargs)
[2021-08-15 21:08:28,521] [ HABApp] ERROR | File "F:\Apps\habapp\lib\site-packages\HABApp\openhab\connection_logic\connection.py", line 48, in on_sse_event
[2021-08-15 21:08:28,521] [ HABApp] ERROR | 38 def on_sse_event(event_dict: dict):
[2021-08-15 21:08:28,522] [ HABApp] ERROR | (...)
[2021-08-15 21:08:28,522] [ HABApp] ERROR | 44 # so the items have the correct state when we process the event in a rule
[2021-08-15 21:08:28,522] [ HABApp] ERROR | 45 try:
[2021-08-15 21:08:28,522] [ HABApp] ERROR | 46 if isinstance(event, HABApp.core.events.ValueUpdateEvent):
[2021-08-15 21:08:28,522] [ HABApp] ERROR | 47 __item = Items.get_item(event.name) # type: HABApp.core.items.base_item.BaseValueItem
[2021-08-15 21:08:28,522] [ HABApp] ERROR | --> 48 __item.set_value(event.value)
[2021-08-15 21:08:28,522] [ HABApp] ERROR | 49 HABApp.core.EventBus.post_event(event.name, event)
[2021-08-15 21:08:28,522] [ HABApp] ERROR | ..................................................
[2021-08-15 21:08:28,523] [ HABApp] ERROR | event_dict = {'topic': 'openhab/items/HallEnvironment_HallSmoke/state',
[2021-08-15 21:08:28,523] [ HABApp] ERROR | 'payload': '{"type":"OnOff","value":"OFF"}',
[2021-08-15 21:08:28,523] [ HABApp] ERROR | 'type': 'ItemStateEvent'}
[2021-08-15 21:08:28,523] [ HABApp] ERROR | event = <ItemStateEvent name: HallEnvironment_HallSmoke, value: OFF>
[2021-08-15 21:08:28,523] [ HABApp] ERROR | HABApp.core.events.ValueUpdateEvent = <class 'HABApp.core.events.events.ValueUpdateEvent'>
[2021-08-15 21:08:28,523] [ HABApp] ERROR | __item = <ContactItem name: HallEnvironment_HallSmoke, value: None, last_change: 2021-08-15T20:55:11.064056, last_update: 2021-08-15T21:05:43.893986>
[2021-08-15 21:08:28,523] [ HABApp] ERROR | Items.get_item = <function 'get_item' Items.py:24>
[2021-08-15 21:08:28,523] [ HABApp] ERROR | event.name = 'HallEnvironment_HallSmoke'
[2021-08-15 21:08:28,523] [ HABApp] ERROR | __item.set_value = <method 'ContactItem.set_value' of # error calling str contact_item.py:7>
[2021-08-15 21:08:28,523] [ HABApp] ERROR | event.value = <HABApp.openhab.definitions.values.OnOffValue object at 0x05C8D310>
[2021-08-15 21:08:28,524] [ HABApp] ERROR | ..................................................
[2021-08-15 21:08:28,524] [ HABApp] ERROR | File "F:\Apps\habapp\lib\site-packages\HABApp\openhab\items\contact_item.py", line 13, in set_value
[2021-08-15 21:08:28,524] [ HABApp] ERROR | 7 def set_value(self, new_value) -> bool:
[2021-08-15 21:08:28,524] [ HABApp] ERROR | (...)
[2021-08-15 21:08:28,524] [ HABApp] ERROR | 9 if isinstance(new_value, OpenClosedValue):
[2021-08-15 21:08:28,524] [ HABApp] ERROR | 10 new_value = new_value.value
[2021-08-15 21:08:28,524] [ HABApp] ERROR | 11
[2021-08-15 21:08:28,525] [ HABApp] ERROR | 12 if new_value is not None and new_value != OpenClosedValue.OPEN and new_value != OpenClosedValue.CLOSED:
[2021-08-15 21:08:28,525] [ HABApp] ERROR | --> 13 raise ValueError(f'Invalid value for ContactItem: {new_value}')
[2021-08-15 21:08:28,525] [ HABApp] ERROR | 14 return super().set_value(new_value)
[2021-08-15 21:08:28,525] [ HABApp] ERROR | ..................................................
[2021-08-15 21:08:28,525] [ HABApp] ERROR | self = <ContactItem name: HallEnvironment_HallSmoke, value: None, last_change: 2021-08-15T20:55:11.064056, last_update: 2021-08-15T21:05:43.893986>
[2021-08-15 21:08:28,525] [ HABApp] ERROR | new_value = <HABApp.openhab.definitions.values.OnOffValue object at 0x05C8D310>
[2021-08-15 21:08:28,525] [ HABApp] ERROR | OpenClosedValue = <class 'HABApp.openhab.definitions.values.OpenClosedValue'>
[2021-08-15 21:08:28,525] [ HABApp] ERROR | new_value.value = 'OFF'
[2021-08-15 21:08:28,525] [ HABApp] ERROR | OpenClosedValue.OPEN = 'OPEN'
[2021-08-15 21:08:28,525] [ HABApp] ERROR | OpenClosedValue.CLOSED = 'CLOSED'
[2021-08-15 21:08:28,526] [ HABApp] ERROR | ..................................................
[2021-08-15 21:08:28,526] [ HABApp] ERROR | ValueError: Invalid value for ContactItem: OFF
[2021-08-15 21:08:37,091] [HABApp.openhab.connection] WARNING | Status 404 for PUT http://localhost:1980/rest/items/HABApp_Ping/state/ NULL
[2021-08-15 21:08:47,114] [HABApp.openhab.connection] WARNING | Status 404 for PUT http://localhost:1980/rest/items/HABApp_Ping/state/ NULL
So not sure if it’s actually working on my system
Is there a specific forum/section I can go to to get help on installation and configuration of HabApp?
Thanks,
Richie
