Trying to access an object variable by reference but its not working the way I want (the list value will not follow the value of the ping_stat.min/max/mean). Is it possible to achieve what I want?
On the first screenshot you append the current value.
If you use the function you get the value at the time when you call the function
Im used to be able to access by pointer/reference to object/value but I think this is not the way its done in python. As long as there is a compact way to do it, like a function call (“pointer”) its fine by me.
