Python question ... sorry :-)
I googled this but not finding a good solution so I thought I’d ask here …
I have two libraries that require functions from each other … I can’t include them in each other without creating a circular definition …
For now, I’m just repeating the library function where I need it, which is sub-optimal. Maybe it’s a matter of rethinking whats in what library module?
I’m assuming someone else here has run across this. It’s making my head hurt … what am I missing?
Just include one at the bottom of the other.
That way you still can include the function.
Thanks Sebastian … Unfortunately I can’t follow you … can you be a little more explicit?
file_a:
from file_b import func_b
def func a():
    func_b()
file_b:
def func_b():
    func_a()
from file_a import func_a
Well, ok I tried that … and it still gives an error (using your example as a test)
2022-07-18 11:18:42.173 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/personal/test.py': ImportError: cannot import name func_a in /etc/openhab/automation/jsr223/python/personal/test.py at line number 1
test_a.py contains:
import personal.file_a
reload(personal.file_a)
from personal.file_a import func_a
Just to be clear, both file_a and file_b are in the library … test.py is in personal space.
At least that’s the way how it can be done in plain python.
The error is for test.py but you are showing the contents of test_a.py
Something like this will work:
def func a():
    func_b()
result is then:
2022-07-19 09:18:04.413 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/personal/test_circ.py': RuntimeError: maximum recursion depth exceeded (Java StackOverflowError) in /openhab/conf/automation/jsr223/python/personal/test_circ.py at line number 6
more ideas can be found here:
https://stackoverflow.com/questions/7336802/how-to-avoid-circular-imports-in-python
sorry … that was just a typo … test.py importing from file_a or file_b has the same error.
Thanks @lukics … I was hoping I was just missing something (other than bad design) … I think the easiest solution is to add a 3rd library that contains the common function. :slight_smile:
Thanks for your responses @Spaceman_Spiff and @lukics
