Python script parameter in ' '
I wrote a simple rule:
rule "Run"
    Item Run received command ON
    val String answer = executeCommandLine("python3 /etc/openhab2/scripts/openstuder-examples-python/cli/sicli.py localhost 'read xcom.xt1.3000'", 5000)
    logInfo("Result=", answer)
Answer should be a string like:
xcom.xt1.3000 = 50.625
But in openhab.log I can see a error message:
2023-06-04 16:59:39.255 [INFO ] [lipse.smarthome.model.script.Result=] - *** Unknown syntax: "read xcom.xt1.3000"
Correct syntax with using ’ ’ please ?
Thanks.
  • Platform information:
    • Hardware: Rpi3
    • OS: Raspbian Bullseye
    • Java Runtime Environment: openjdk version “1.8.0_312”
    • openHAB version: 2.15 last
OH 2.5 is really old now. IIRC you need to replace spaces between command line arguments with @@.
Beyond that, the error is coming from your Python script so :person_shrugging: . Add some logging to your Python script, modify it to handle the read xcom.xt1.3000 as a single command line argument (that’s what happens when you pass it in quotes like that).
Try running it with those arguments from the command line using the openhab user.
sudo -u openhab python3 /etc/openhab2/scripts/openstuder-examples-python/cli/sicli.py localhost 'read xcom.xt1.3000'
Thanks Rich.
Result:
xcom.xt1.3000 = 50.53125
Same with @@ (chown root:root but chmod=777)
val String answer = executeCommandLine(“/etc/openhab2/scripts/openstuder-examples-python/cli/./sicli@@localhost@@‘read xcom.xt1.3000’”, 5000)
[INFO ] [lipse.smarthome.model.script.Result=] - *** Unknown syntax: “read xcom.xt1.3000”
Maybe I will try to modify calling python script with params without ’ ’
No problem if parameter inside ’ ’ is only one string, e.g.
 val String answer = executeCommandLine("python3 /etc/openhab2/scripts/openstuder-examples-python/cli/sicli localhost 'info'", 5000)
Answer:
2023-06-05 10:27:20.985 [INFO ] [lipse.smarthome.model.script.Result=] - client state: CONNECTED
gateway version: 0.3.3
access level: QUALIFIED_SERVICE_PERSONNEL
Eclipse has problem with points inside string e.g.‘xcom.xt1.3000’
