Python script with executecommandline
I have a python script that works fine from the command line but doesnt when calling from executecommandline.
Hoping someone can help
command:
strCommand = "/usr/bin/python@@/opt/openhab/configurations/scripts/lifxstate.py"
executeCommandLine(strCommand, 5000)
the script::
    #!/usr/bin/env python
import requests
import time
token = ''mytokenhere''
headers = {
    "Authorization": "Bearer %s" % token,
def restore_state(state):
    selector = 'id:%s' % state['id']
    # Color is sent as one string, so we have to convert it
    color_items = state['color'].items()
    color_strings = map(lambda x:'%s:%s' % x, color_items)
    data = {
        'power': state['power'],
        'brightness': state['brightness'],
        'color': ' '.join(color_strings),
    response = requests.put('https://api.lifx.com/v1/lights/%s/state' % selector, data=data, headers=headers)
def fetch_states(selector='all'):
    response = requests.get('https://api.lifx.com/v1/lights/' + selector, headers=headers)
    return response.json()
print 'Storing the current state of the bulbs'
orig_states = fetch_states()
print 'Waiting 10 seconds, change the color of the bulbs now'
time.sleep(10)
print 'Restoring lights to the state they were 10 seconds ago'
for state in orig_states:
Change your rule code to log out what the script is returning:
val results = executeCommandLine(strCommand, 5000)
logInfo("exec", results)
If I had to guess the problem may be with the #!/usr/bin/env python. The user openHAB runs under doesn’t have a shell so evn may not be able to run.
I did try that and the log shows a loginfo entry with no return value
Any idea what I should be putting in the top of the script?
Things to try:
  • I am pretty sure you don’t need the “@@” for spaces when using executeCommandLine. And even if you did, I don’t think it is needed in this case.
  • make sure python is in /usr/bin
  • replace the line at the top with #!/usr/bin/python
I had this same issue.
I read a suggestion somewhere to write a shell script which just contains the command to run the python script. So something like:
#!/bin/sh
/usr/bin/python /opt/openhab/configurations/scripts/lifxstate.py
Save that lifxstate.sh.
Then chmod +x lifxstate.sh to make it executable.
Now try
executeCommandLine("/opt/openhab/configurations/scripts/lifxstate.sh")
No idea why this works, but it does for me.
So I dropped it back to a 1 liner:
executeCommandLine(“/usr/bin/python@@/opt/openhab/configurations/scripts/lifxstate.py”)
is now working for me.
Pretty sure the @@ are needed for spaces in executeCommandLine syntax
I have a number of executeCommandLine calls, all of which have spaces, none of which use @@. So I can say it is not always required and in my experience not required as often as it is when using the Exec binding.
executeCommandLine("chmod a+x /etc/openhab/configurations/scripts/resetGarageSensorReporter.sh", 5000)
executeCommandLine("chmod go-r /var/lib/openhab/.ssh/authorized_keys2 /var/lib/openhab/.ssh/id_rsa /var/lib/openhab/.ssh/id_rsa.pub /var/lib/openhab/.ssh/known_hosts /var/lib/openhab/.ssh/known_hosts.old", 5000)
executeCommandLine("/etc/openhab/configurations/scripts/resetGarageSensorReporter.sh", 5000)
executeCommandLine("/etc/openhab/configurations/scripts/searchRokus.py", 20000)
OK now I haev it all working - I will pull them out and see if it still does - would certainly make the code tidier. Perhaps Im getting confused with curl commands.
