Python Scripting Next [5.1.0.0;5.2.0.0)
This add-on is a preview version of the next Python Scripting release.
It contains all features of the official Add-on, plus many changes, described below.
Maybe an openhab restart is necessary, if jsscripting is installed in parallel
Quick Start
  1. Uninstall any active “Python Scripting” Add-on
  2. Click “Install” or copy Kar file to your “/addons” folder
  3. Restart openhab (optional)
Documentation
Please refer the Add-on README or the Helper Lib README
If you have question, feel free to post it on the discussion thread
Ressources
Kar file (OH5.1+)
Source code
Last published Date
Last Update: 01.03..2026 16:14
Changelog
Version 01.03..2026 16:14
(This is the same version as the merged one in upcoming openhab 5.2.0)
Add-on changes
  • Reintroduce scriptUnloaded function. Was possible after another fix
  • Simplify binding config
  • Update helper lib to version 1.0.18
Helper lib 1.0.15 - 1.0.18 changed
  • fix wrong log prefix initialisation for file and ui based rules
  • Simplify error message handling and format. This results in much simpler function call stack which improves the performance in nearly all aspects of helper lib and java (foreign) object calls.
Base Version
  • Same version as the official binding in openhab 5.1.0
This thread is only for marketplace updates. For discussion use our Python3 Binding Thread
