- Platform information:
- Hardware: Acer Aspire 5315 2Gb RAM
- OS: _Debian GNU/Linux 9 (stretch)
- Java Runtime Environment: OpenJDK Runtime Environment (Zulu 8.30.0.1-linux64) (build 1.8.0_172-b01)
- openHAB version: openHAB 2.3.0-1 (Release Build)
- zwave version: 2.4.0.201807161453
I have a Qubino ZMNHBD Flush 2 Relais firmware version 5.0 from Qubino that is connected to a be-stable switch, my bathroom light and my bathroom ventilation. My goal is to switch on light and ven when the hardware switch is used, and only switch off the light when it is switched off again. Then a timer will run for 5 minutes and when it ends, the ven will switch off too. In time I would like to make the use of the timer depend the time of day.
Most times this works great, but every once in a while the Qubino behaves differently. After pushing the switch, light will go on, but not the ven. Then after several seconds, the light will go off, and again after several seconds, both the light and the ven will go on. Sometimes, but not every time, I can hear the Qubino switch several times without anything happening before switching the light and ven on. This is very disturbing for my small kids when they go to the bathroom at night.
I moved from Raspi to the laptop and changed to the snapshot version of the zwave binding, hoping this would solve my problem. But it is still the same as with the stable binding.
I never have this strange switching behaviour when I switch on the light through the app, only when we push the be-stable-switch.
Default reporting group: Openhab Controller.
Only sw1 and sw2 have items connected.
My log only shows the intended switching:
2018-07-21 13:49:43.371 [vent.ItemStateChangedEvent] - Lamp_BK changed from ON to OFF
2018-07-21 13:49:43.372 [ome.event.ItemCommandEvent] - Item 'Ven_BK_timer' received command ON
2018-07-21 13:50:56.064 [vent.ItemStateChangedEvent] - Lamp_BK changed from OFF to ON
2018-07-21 13:50:56.067 [ome.event.ItemCommandEvent] - Item 'Ven_BK' received command ON
2018-07-21 13:51:05.078 [ome.event.ItemCommandEvent] - Item 'Ven_BK_timer' received command ON
2018-07-21 13:51:05.080 [vent.ItemStateChangedEvent] - Lamp_BK changed from ON to OFF
2018-07-21 13:56:05.716 [ome.event.ItemCommandEvent] - Item 'Ven_BK_timer' received command OFF
2018-07-21 13:56:05.720 [vent.ItemStateChangedEvent] - Ven_BK_timer changed from ON to OFF
2018-07-21 13:56:05.723 [ome.event.ItemCommandEvent] - Item 'Ven_BK' received command OFF
2018-07-21 13:56:05.727 [vent.ItemStateChangedEvent] - Ven_BK changed from ON to OFF
items:
Switch Lamp_BK "Licht badkamer" <switch> { channel="zwave:device:e246413d:node24:switch_binary1"}
Switch Ven_BK "Ventilator badkamer" <switch> { channel="zwave:device:e246413d:node24:switch_binary2"}
Switch Ven_BK_timer { expire="5m,command=OFF" }
rules:
rule "Ven_badkamer"
Item Lamp_BK changed
if(Lamp_BK.state==ON){
Ven_BK.sendCommand(ON)
if(Lamp_BK.state==OFF){
Ven_BK_timer.sendCommand(ON)
rule "Ven_bad_uit"
Item Ven_BK_timer changed //from ON to OFF
if (Lamp_BK.state==OFF && Ven_BK_timer.state==OFF){
Ven_BK.sendCommand(OFF)
The problem is when the first rule works but I have post the second too in case it could be relevant.
There are some errors in my log that are about other nodes which I don’t understand but I don’t think is relevant.
I also tryed the rule on another Flush2relais that I have, with the same result!
How could I try to solve this?
