If OH1 is generating the XML file (in the /etc/userdata folder) then you should be able to use this to create the outline of the database entry…
Create a login on the database site
Let me know when it’s done as I’ll need to update your access so you can add/edit entries
From the main device list, there’s a tools menu in the top right. Click on this and click “Add Device from openHAB file” (or something similar). Type the name of the device into the form, and cut and paste the XML into the appropriate place.
Click go, and hopefully it will generate the entry…
Ultimately, we’ll also need for someone to type in the configuration data. IF you have a manual, it would be good to also upload it to the database (there’s a section at the bottom of the page for uploading manuals).
Thanks for looking at this - if you have any issues, please let me know.
Yes, if we can get the data into the online database, then there is a button to generate the OH1 and OH2 database files. Basically the database contains all the information, and from there we can format the data however we like - OH1/OH2, or another way
ok, I have made an entry, but I just put in one config parameter, could you please check it when you have the time. Will continue to put more if thats the way…
