BruinsmM
(Martin Bruinsma)
February 20, 2017, 11:03am
#1
In the PaperUI i can switch the lamp on/off. The log shows the following info:
11:48:03.787 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_device_2d273097_node2_switch_binary1 changed from ON to OFF
When i use the real switch which is connected to the Qubino relay, the paperUI doesn’t update it state. The log says nothing. How can i fix this problem?
vossivossi
(vossivossi)
February 20, 2017, 11:09am
#2
I think you have the same problems that we discuss in this thread
vossivossi:
@chris : As already stated in the FGS-223 thread, the Qubino ZMNHBD is still NOT working (I tested with Z-Wave binding build 2.1.0.201702181609). I excluded and freshly reincluded 2 of the devices to be sure. The results: 1. When only the lifeline association is set, no reporting is done to endpoints 1 and 2 (neither for Switch 1/2 nor Power(Watts)1/2). 2. Even when the association groups for Switch binary or Basic On/Off are set (or both, also tested), NO update comes to the controller for Swi…
BruinsmM
(Martin Bruinsma)
February 25, 2017, 10:25pm
#3
When i change the polling period from 15 M to 15 in HABmin, the switch in the paperUI works fine, when i use the physical switch.
vossivossi
(vossivossi)
February 25, 2017, 10:46pm
#4
I do not understand exactly what is the difference between 15M and 15? Do you choose another unit of measure than minutes?
BruinsmM
(Martin Bruinsma)
February 25, 2017, 10:51pm
#5
15 = 15 seconds, 15 M = 15 minutes
vossivossi
(vossivossi)
February 26, 2017, 8:32am
#6
Polling a device every 15 seconds is not the way things should work. Soon or later it will affect the network performance if you add more nodes.
BruinsmM
(Martin Bruinsma)
February 26, 2017, 10:06am
#7
sorry you’re right. I thought this would be the solution.
Can user CDJackson fix this problem?
In the PaperUI i can switch the lamp. Not in the BasicUI. Have you a working solution for the BasicUI?
