anyone using this device knows the difference between meter_watts and meter_watts1 from the documentation is written:
*1NOTE: ENDPOINT1 is a copy of ROOT. ROOT is used in single channel configuration. For the
correct display of all values multichannel lifeline has to be used.
But I got 2 totally different values, may be it’s the difference with the solar implant?
As far as I understand the documentation the device supports one channel with overall consumption and additional channels for each phase. How does your use case for the smart meter look like ?
No because there is endpoint 1 that is L1+L2+L3 there is endpoint 0 that is ROOT that from documentation is the same (but valuea reported are different) the there is endpoint 2,3,4 (so in total 5 endpoints)
