I have Group definitions like
Group:Dimmer:MIN gDimm "All Dimmed Lights"
Group:Switch:MIN gSwitchedLight "All Switched Lights"
When calling up GetType on these groups, “Group” is returned.
How can I query the subtype “Dimmer/Switch”?
This might work:
if(gDimm instance of DimmerType)
The question is why do you need to do this? There might be another way to accomplish what you are after.
For example, you can send ON/OFF commands to Dimmers so it may not matter what type it is.
You can also get the state of Items as different types. For example, because Dimmer and Color Items can receive be commanded with ON/OFF, you can also get their current state as those types.
MyDimmerItem.getStateAs(OnOffType)
What I have seen is that if I perform following operation on a dimmer (in particular osram lightify):
I get get a flash between step 2&3.
so I have to make sure to switch of dimmers by set state to 0
And just to mention: I am too getting the feeling that I am full off track with lamda-crazy-solution, but not tried, not failed.
Is Color also instance of DimmerType?
Yes.
Color is a Dimmer and a Switch
Dimmer is a Switch
So you can, for example, send an ON to a Color Item or a Dimmer Item. You can send a single PercentType to a Color or a Dimmer to adjust brightness.
An item of type GroupItem provides the method getBaseItem() that will return the group item’s base item, the type of which you can query with the method getType(). Note that getBaseItem() returns a null if the provided group item has no base item.
Untested example usage:
var groupBaseType = gMyGroupItem.getBaseItem()?.getType()
Rich’s advice is sound, I use groups of lights that are a mix of Dimmer and Switch items exactly the way Rich describes their use above.
I get following error:
'getBaseItem' is not a member of 'org.eclipse.smarthome.core.items.GroupItem'; line 18, column 46, length 19
Implemented the check this way:
gMyGroupItem.acceptedCommandTypes.contains(PercentType)
Which separates dimmer from switches regardless if it is an single item or group.
Works for me.
logInfo(logID, "gOFLtsOn groupBaseType: {}", gOFLtsOn.getBaseItem().getType().toString())
When the rule containing that line is executed, the following appears in openhab.log:
2018-12-14 07:21:17.938 [INFO ][SH-ruleEngine-4][vation-azimuth.rules.ofc-all-off-led] - gOFLtsOn groupBaseType: Switch
Platform here is openHABian on RPi 3B, 2.4.0-SNAPSHOT, Build #1445.
Can you post your relevant items and rules file(s)?
2.3.0 Stable, got a solution, see above.
here the rules file: ![]()
import java.util.Map
val Number NO_TIMEOUT = -1
val Number FORGOT_TIMEOUT = 60*60*5
val Number STAIRS_TIMEOUT = 60
val Number EXTENDED_TIMEOUT = 2*60
val Number STAIRS_ILUMINATION = 100
val Number ENTRY_ILUMINATION = 70
val Number WORK_ILUMINATION = 230
val Number INGNORE_ILUMINATION = 255
val java.util.concurrent.ConcurrentHashMap<String, Timer> lightTimers = new java.util.concurrent.ConcurrentHashMap()
val java.util.concurrent.ConcurrentHashMap<String, DateTime> lightTimersExpiration = new java.util.concurrent.ConcurrentHashMap()
val lightManager = [ GenericItem light, Number level, Boolean keepLevel |
try{
logInfo("lightManager", " <"+light.label + "> : start")
if (light.acceptedCommandTypes.contains(PercentType) ) {
logInfo("lightManager", " <"+light.label + "> : *** dimmer type ***, target level: " + level + " Light level: "+ light.state )
// make sure not to go over 100
if (!keepLevel || light.state <= level) sendCommand(light, if (level > 100) 100 else level)
logInfo("lightManager", " <"+light.label + "(1)> " )
else {
logInfo("lightManager", " <"+light.label + "> : *** Switch type ***" )
sendCommand(light, if (level > 0) ON else OFF)
} catch(Exception e) {
logInfo("lightManager", " Exception : " + e.getLocalizedMessage)
sendCommand(light, "0")
return true
val lightTimerManager = [ GenericItem light, GenericItem motion, Functions$Function3<GenericItem, Number, Boolean, Boolean> lightMgr, Number timeout, Map<String, Timer> timers, Map<String, DateTime> timersExpiration |
try{
// timeout -1 means reset timer e.g. light toggeled OFF
if (timeout > 0 ){
logInfo("lightTimerManager", " <"+light.label + "> : size of timers HM before: " + timers.size)
// Is there a time already running for item and timer is runing (timersExpiration > now)
if (timers.containsKey(light.label) && timers.get(light.label) !==null && timersExpiration.get(light.label) > now ){
// Is the current running timer shorter that new needed
if (timersExpiration.get(light.label) < now.plusSeconds(timeout.intValue)){
// yes, so extend timer and store new timeout in table
timersExpiration.put(light.label, now.plusSeconds(timeout.intValue))
timers.get(light.label).reschedule(now.plusSeconds(timeout.intValue))
logInfo("lightTimerManager", "<"+light.label + "> : found and extend timer ")
else {
// no timer runnimg create a new one and store new timeout in table
logInfo("lightTimerManager", " <"+light.label + "> : create timeout")
timers.put(light.label, createTimer(now.plusSeconds(timeout.intValue), [|
logInfo("lightTimerManager", "<"+light.label + "(1)> : expired timer, motion: " + motion.state)
if (motion !== null && motion.state == ON) {
logInfo("lightTimerManager", "<"+light.label + "(1)> : expired timer, but motion still active")
timers.get(light.label). reschedule(now.plusSeconds(timeout.intValue))
else {
logInfo("lightTimerManager", "<"+light.label + "(2)> : expired timer")
lightMgr.apply(light, 0, false)
} else if (timers.containsKey(light.label) && timers.get(light.label) !==null){
// Cancel timer and set it to null
logInfo("lightTimerManager", " <"+light.label + "(1)> : cancel timer")
timers.get(light.label).cancel()
timersExpiration.put(light.label, now)
logInfo("lightTimerManager", " Exception : " + e.getLocalizedMessage)
return true
val dimmLight= [ GenericItem light, Functions$Function3<GenericItem, Number, Boolean, Boolean>lightMgr|
try{
logInfo("dimmLight ", "<"+light.label + "> ")
// incremet by 5% light manager does not to go over 100%
lightMgr.apply(light, light.state as Number + 5, false)
logInfo("dimmLight ", "<"+light.label + "> state : " + light.state.toString)
logInfo("toggleLight", " Exception : " + e.getLocalizedMessage)
return true
val toggleLight= [ GenericItem light, Functions$Function3<GenericItem, Number, Boolean, Boolean> lightMgr|
// retvalue is used to reset timer if light switched off
var retValue = false
try{
logInfo("toggleLight ", "<"+light.label + "> ")
if ( light.getStateAs(OnOffType) == OFF) {
logInfo("toggleLight ", "<"+light.label + "(1)> ")
if (isBedTime.state == ON){
logInfo("toggleLight ", "<"+light.label + "(2)> ")
lightMgr.apply(light, 5, false)
else {
logInfo("toggleLight ", "<"+light.label + "(3)> ")
lightMgr.apply(light, 100, false)
retValue = true
else {
logInfo("toggleLight ", "<"+light.label + "(4)> ")
return retValue
val motionOnLight= [GenericItem ilumination, GenericItem light, Number ilmLimit, Functions$Function3<GenericItem, Number, Boolean, Boolean> lightMgr, Boolean allDay |
// retvalue used to start timer, not all calls to motionOnLight actually switches light on
try{
logInfo("motionOnLight", "<" + light.label + "> : started, ilumination : "+ ilumination.state + " limit : " + ilmLimit.toString )
// Is is not bed time and it is dark enough so it makes sense to switch on
if ((isBedTime.state == OFF || allDay) && ((ilumination.state as Number) <= ilmLimit)) {
// out of the threshold calculate min 5 and max 100 values
var Number calculatedLevel = 5 + ((ilumination.state as Number + 5) * 95 / ilmLimit)
// setting threshold to 255 mean, ignoring it, so set target level to 100
var Number targetLevel = if ( ilmLimit < 255 ) calculatedLevel else 100
// only set value if current light power is lower
lightMgr.apply(light, targetLevel, true)
logInfo("motionOnLight", light.label + ": targetLevel : "+ targetLevel.toString )
retValue = true
logInfo("motionOnLight", " Exception : " + e.getLocalizedMessage)
return retValue
rule "Initiate lightControl.rules"
System started
logInfo("Initiate lightControl.rules", "finished")
// ************************ Rules Start **************************
// ************************ Entry/Outside **************************
rule "Entry toggle light"
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:1#PRESS" triggered SHORT
lightTimerManager.apply(EntryLight, null, lightManager, if (toggleLight.apply(EntryLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Entry Outside toggle light"
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:2#PRESS" triggered SHORT
lightTimerManager.apply(EntryOutsideLight, null, lightManager, if (toggleLight.apply(EntryOutsideLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Entry dimm light"
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:1#PRESS" triggered LONG or
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:2#PRESS" triggered LONG or
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:1#PRESS" triggered CONT or
Channel "homematic:HmIP-SMI55:87ff2485:0014D709AEF787:2#PRESS" triggered CONT
dimmLight.apply(EntryLight, lightManager)
lightTimerManager.apply(EntryLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Entry motion light "
Item EntryMotion changed to ON
if (motionOnLight.apply(EntryIlumination, EntryLight, STAIRS_ILUMINATION, lightManager, false))
lightTimerManager.apply(EntryLight, EntryMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Entry external motion light "
Item EntryOutsideMotion changed to ON
if (motionOnLight.apply(EntryOutsideIlumination, EntryOutsideLight, STAIRS_ILUMINATION, lightManager, true))
lightTimerManager.apply(EntryOutsideLight, EntryOutsideMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Hallway **************************
rule "Hallway toggle light"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:2#PRESS" triggered SHORT
lightTimerManager.apply(HallwayDownLight, null, lightManager, if (toggleLight.apply(HallwayDownLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Hallway dimm light"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961383:2#PRESS" triggered CONT
dimmLight.apply(HallwayDownLight, lightManager)
lightTimerManager.apply(HallwayDownLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Hallway motion light "
Item HallwayDownMotion changed to ON
if (motionOnLight.apply(HallwayDownIlumination, HallwayDownLight, STAIRS_ILUMINATION, lightManager, false))
lightTimerManager.apply(HallwayDownLight, HallwayDownMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Stair/Hallway **************************
rule "StairsHallway toggle light"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:2#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:2#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:2#PRESS" triggered SHORT
lightTimerManager.apply(StairsHallwayLight, null, lightManager, if (toggleLight.apply(StairsHallwayLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "StairsHallway dimm light"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961397:2#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961368:2#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964574:2#PRESS" triggered CONT
dimmLight.apply(StairsHallwayLight, lightManager)
lightTimerManager.apply(StairsHallwayLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "StairsHallway motion light "
Item g_StairsHallwayMotion changed to ON
if (motionOnLight.apply(g_StairsHallwayIlumination, StairsHallwayLight, STAIRS_ILUMINATION, lightManager, false))
lightTimerManager.apply(StairsHallwayLight, g_StairsHallwayMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Guestroom **************************
rule "GuestRoom Light Top toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:1#PRESS" triggered SHORT
lightTimerManager.apply(GuestTopLight, null, lightManager, if (toggleLight.apply(GuestTopLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "GuetsRoom TopLight dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:1#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:1#PRESS" triggered CONT
dimmLight.apply(GuestTopLight, lightManager)
lightTimerManager.apply(GuestTopLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "GuestRoom Light Standlamp toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:3#PRESS" triggered SHORT
lightTimerManager.apply(GuestRoomStandLamp, null, lightManager, if (toggleLight.apply(GuestRoomStandLamp, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "GuetsRoom Standlamp dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:3#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001867:3#PRESS" triggered CONT
dimmLight.apply(GuestRoomStandLamp, lightManager)
lightTimerManager.apply(GuestRoomStandLamp, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ StudyRoom **************************
rule "StudyRoom Top Lamp toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001224:1#PRESS" triggered SHORT
lightTimerManager.apply(StudyRoomLightTop, null, lightManager, if (toggleLight.apply(StudyRoomLightTop, lightManager)) FORGOT_TIMEOUT else -1 , lightTimers, lightTimersExpiration)
rule "StudyRoom Top Lamp dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001224:1#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001224:1#PRESS" triggered CONT
dimmLight.apply(StudyRoomLightTop, lightManager)
lightTimerManager.apply(StudyRoomLightTop, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Dining/Living Room **************************
rule "Dining Room Spots dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:1#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:3#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:1#PRESS" triggered CONT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:3#PRESS" triggered CONT
dimmLight.apply(gTFDRLightSpot, lightManager)
lightTimerManager.apply(gTFDRLightSpot, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Dining Room Spots toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:1#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:3#PRESS" triggered SHORT
lightTimerManager.apply(gTFDRLightSpot, null, lightManager, if (toggleLight.apply(gTFDRLightSpot, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Dining Room Table dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:2#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:4#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:2#PRESS" triggered CONT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:4#PRESS" triggered CONT
dimmLight.apply(gTFDRLightTop, lightManager)
lightTimerManager.apply(gTFDRLightTop, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Dining Room Table toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:2#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:4#PRESS" triggered SHORT
lightTimerManager.apply(gTFDRLightTop, null, lightManager, if (toggleLight.apply(gTFDRLightTop, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Living Room Spots dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:3#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:3#PRESS" triggered CONT
dimmLight.apply(gTFWZLightSpot, lightManager)
lightTimerManager.apply(gTFWZLightSpot, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Living Room Spots toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:3#PRESS" triggered SHORT
lightTimerManager.apply(gTFWZLightSpot, null, lightManager, if (toggleLight.apply(gTFWZLightSpot, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Living Room Table dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:4#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:4#PRESS" triggered CONT
dimmLight.apply(gTFWZLightTop, lightManager)
lightTimerManager.apply(gTFWZLightTop, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Living Room Table toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:4#PRESS" triggered SHORT
lightTimerManager.apply(gTFWZLightTop, null, lightManager, if (toggleLight.apply(gTFWZLightTop, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Living Room Standlamp toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:6#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001241:6#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:6#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:6#PRESS" triggered SHORT
lightTimerManager.apply(LivingRoomStandLamp, null, lightManager, if (toggleLight.apply(LivingRoomStandLamp, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Living Room Chair Lamp dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:5#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:5#PRESS" triggered CONT
dimmLight.apply(LivingRoomChairLamp, lightManager)
lightTimerManager.apply(LivingRoomChairLamp, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Living Room Chair Lamp toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:5#PRESS" triggered SHORT
lightTimerManager.apply(LivingRoomChairLamp, null, lightManager, if (toggleLight.apply(LivingRoomChairLamp, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
// ************************ Kitchen **************************
rule "KitchenWorktop dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:1#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:1#PRESS" triggered CONT
dimmLight.apply(TFKichenWorkTop, lightManager)
lightTimerManager.apply(TFKichenWorkTop, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "KitchenWorktop toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001902:1#PRESS" triggered SHORT
lightTimerManager.apply(TFKichenWorkTop, null, lightManager, if (toggleLight.apply(TFKichenWorkTop, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
// ************************ Boiler Room **************************
rule "Boiler Room toggle"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:2#PRESS" triggered SHORT
lightTimerManager.apply(BoilerRoomLight, null, lightManager, if (toggleLight.apply(BoilerRoomLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Boiler Room dimm"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:2#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0962519:2#PRESS" triggered LONG
dimmLight.apply(BoilerRoomLight, lightManager)
lightTimerManager.apply(BoilerRoomLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Boiler Room motion"
Item BoilerRoomMotion changed to ON
if (motionOnLight.apply(BoilerRoomIlumination, BoilerRoomLight, STAIRS_ILUMINATION, lightManager, false))
lightTimerManager.apply(BoilerRoomLight, BoilerRoomMotion, lightManager, EXTENDED_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Pantry Room **************************
rule "PantryRoom motion light"
Item PantryMotion changed to ON
if (motionOnLight.apply(PantryIllumination, PantryLight, WORK_ILUMINATION, lightManager, false))
lightTimerManager.apply(PantryLight, PantryMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
rule "PantryRoom light toggle"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:2#PRESS" triggered SHORT
lightTimerManager.apply(PantryLight, null, lightManager, if (toggleLight.apply(PantryLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "PantryRoom light dimm"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:2#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:MEQ1848771:2#PRESS" triggered LONG
dimmLight.apply(PantryLight, lightManager)
lightTimerManager.apply(PantryLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Locker Room **************************
rule "LockerRomm light toggle"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:2#PRESS" triggered SHORT
lightTimerManager.apply(LockerRoomLight, null, lightManager, if (toggleLight.apply(LockerRoomLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "LockerRomm light dimm"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:1#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:2#PRESS" triggered CONT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0964632:2#PRESS" triggered LONG
dimmLight.apply(LockerRoomLight, lightManager)
lightTimerManager.apply(LockerRoomLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "LockerRoom motion light "
Item LockerRoomMotion changed to ON
if (motionOnLight.apply(LockerRoomIlumination, LockerRoomLight, STAIRS_ILUMINATION, lightManager, false))
lightTimerManager.apply(LockerRoomLight, LockerRoomMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
// ************************ Bedroom **************************
rule "Bed Headlight dimm"
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:1#PRESS" triggered LONG or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:1#PRESS" triggered LONG or
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:2#PRESS" triggered LONG or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:2#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:3#PRESS" triggered LONG or
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:1#PRESS" triggered CONT or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:1#PRESS" triggered CONT or
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:2#PRESS" triggered CONT or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:2#PRESS" triggered CONT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:3#PRESS" triggered CONT
dimmLight.apply(BedRoomBedLight, lightManager)
lightTimerManager.apply(BedRoomBedLight, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Bed Head Light Toggle"
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:1#PRESS" triggered SHORT or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:1#PRESS" triggered SHORT or
Channel "homematic:HM-PB-2-WM55:87ff2485:OEQ0484128:2#PRESS" triggered SHORT or
Channel "homematic:HMIP-WRC2:87ff2485:000193C98CA4FE:2#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:3#PRESS" triggered SHORT
if (toggleLight.apply(BedRoomBedLight, lightManager)){
else {
lightTimerManager.apply(BedRoomBedLight, null, lightManager, NO_TIMEOUT, lightTimers, lightTimersExpiration)
// This will drag down gTFDRLightBed light too
lightTimerManager.apply(gTFDRLightBed, null, lightManager, NO_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Bed Table lamps dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:4#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:4#PRESS" triggered CONT
dimmLight.apply(gTFDRLightBed, lightManager)
lightTimerManager.apply(gTFDRLightBed, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Bed table Lamps toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001787:4#PRESS" triggered SHORT
lightTimerManager.apply(gTFDRLightBed, null, lightManager, if (toggleLight.apply(gTFDRLightBed, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule BedRoomClosetLights
Item g_BRClContacts changed
// logInfo("BedRoomClosetLight", "triggered")
try{
if ( g_BRClContacts.state as OpenClosedType == OPEN && isBedTime.state == OFF )
{ sendCommand(BedRoomTopSpots, "100")}
else {
createTimer(now.plusSeconds(1), [|
if (g_BRClContacts.state as OpenClosedType == CLOSED) sendCommand(BedRoomTopSpots, "0") ])
} catch(Exception e) {sendCommand(BedRoomTopSpots, "0")}
// ************************ Toilet **************************
rule "ToiletRoom motion light"
Item ToiletMotion changed to ON
if (motionOnLight.apply(ToiletIlumination, ToiletLightWall, INGNORE_ILUMINATION, lightManager, false))
lightTimerManager.apply(ToiletLightWall, ToiletMotion, lightManager, EXTENDED_TIMEOUT, lightTimers, lightTimersExpiration)
rule "ToiletRoom light toggle"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961367:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961367:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961367:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961367:2#PRESS" triggered SHORT
lightTimerManager.apply(ToiletLightMirror, null, lightManager, if (toggleLight.apply(ToiletLightMirror, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "ToiletRoom light dimm"
// ************************ Garage **************************
rule "Garage overall motion light"
Item g_GarageMotion changed to ON
if (motionOnLight.apply(g_GarageIlumination, GarageLight, WORK_ILUMINATION, lightManager, true))
lightTimerManager.apply(GarageLight, g_GarageMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Garage Desk motion light"
Item GarageMotionWorkdesk changed to ON
if (motionOnLight.apply(g_GarageIlumination, GarageWorkdeskSocket, WORK_ILUMINATION, lightManager, true))
lightTimerManager.apply(GarageWorkdeskSocket, g_GarageMotion, lightManager, STAIRS_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Garage light toggle"
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961436:1#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961436:2#PRESS" triggered LONG or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961436:1#PRESS" triggered SHORT or
Channel "homematic:HM-Sen-MDIR-WM55:87ff2485:NEQ0961436:2#PRESS" triggered SHORT
lightTimerManager.apply(GarageLight, null, lightManager, if (toggleLight.apply(GarageLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
// ************************ Terrasse **************************
rule "Terrasse Stand Lamp dimm"
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001214:2#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:2#PRESS" triggered LONG or
Channel "homematic:HM-PB-6-WM55:87ff2485:NEQ1001214:2#PRESS" triggered CONT or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:2#PRESS" triggered CONT
dimmLight.apply(TerrasseStandLamp, lightManager)
lightTimerManager.apply(TerrasseStandLamp, null, lightManager, FORGOT_TIMEOUT, lightTimers, lightTimersExpiration)
rule "Terrasse Stand Lamp toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:2#PRESS" triggered SHORT or
lightTimerManager.apply(TerrasseStandLamp, null, lightManager, if (toggleLight.apply(TerrasseStandLamp, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Terrasse Xmas Light toggle"
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:3#PRESS" triggered SHORT or
Channel "homematic:HM-PB-6-WM55:87ff2485:OEQ0284543:3#PRESS" triggered CONT
lightTimerManager.apply(gXMasLight, null, lightManager, if (toggleLight.apply(gXMasLight, lightManager)) FORGOT_TIMEOUT else -1, lightTimers, lightTimersExpiration)
rule "Terrasse Xmas Light ON"
Time cron "0 0 16 1/1 * ? *"
lightManager.apply(gXMasLight, 100, false)
rule "Terrasse Xmas Light OFF"
Time cron "0 30 23 1/1 * ? *"
lightManager.apply(gXMasLight, 0, false)
The item light in your lambda lightManager is declared as a GenericItem, not a GroupItem.
True, but a the end im some cases a group is passed in the chain of all lambdas:
e.g. : toggleLight → lightTimerManager → lightManager
Group:Switch:MIN gXMasLight "All Switched Lights" (gSwitchedLight)
Switch TreeXMasLight "Tree XMas Light [MAP(on-off.map):%s]" <switch> (gXMasLight) { channel="homematic:HM-LC-Sw1-FM:87ff2485:NEQ0211971:1#STATE"}
Switch GardenMotion "Garden Motion [MAP(on-off.map):%s]" <switch> (gXMasLight) { channel="wemo:socket:Socket-1_0-221417K01006DB:state"}
