Ok,
I have an update for this.
Tried it with a simple example
Items:
witch StartUp "StartUp Switch" // triggers rules to with defined delay after system startup
Switch TestSwitch "Test Switch" // to test manuell rule triggers during delay
String Result "Result" // shows result string
Rule file 1
rule "StartUp"
System started
logDebug("RULES", "+++ Rule 'StartUp' started +++")
StartUp.sendCommand(OFF)
Thread::sleep(60000)
StartUp.sendCommand(ON)
Thread::sleep(3000)
logDebug("RULES", "--- Rule 'StartUp' completed ---")
Rule file 2
rule "Test"
Item TestSwitch received command
logDebug("RULES", "+++ Rule 'Test' started +++")
Result.postUpdate("Test rule triggered via REST")
logDebug("RULES", "--- Rule 'Test' completed ---")
rule "Test2"
Item StartUp received command ON
logDebug("RULES", "+++ Rule 'Test2' started +++")
Result.postUpdate("Test2 rule triggered via StartUp rule")
logDebug("RULES", "--- Rule 'Test2' completed ---")
I tried it with 2.1.0 release build und 2.2.0 SNAPSHOT build #1017
Same result for both versions.
Here are the logs (with some comments) for 2.1.0
*** STARTUP openhab 2.1.0 release build ***
2017-08-18 18:40:15.749 [INFO ] [org.apache.felix.fileinstall ] - Updating configuration from org.ops4j.pax.logging.cfg
2017-08-18 18:40:16.283 [WARN ] [les.properties.AutoEncryptionSupport] - User limit of inotify watches reached
java.io.IOException: User limit of inotify watches reached
at sun.nio.fs.LinuxWatchService$Poller.implRegister(LinuxWatchService.java:264)[:1.8.0_144]
at sun.nio.fs.AbstractPoller.processRequests(AbstractPoller.java:260)[:1.8.0_144]
at sun.nio.fs.LinuxWatchService$Poller.run(LinuxWatchService.java:329)[:1.8.0_144]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_144]
2017-08-18 18:40:16.345 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.bundle.core/4.0.8
2017-08-18 18:40:16.364 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.config.core/4.0.8
2017-08-18 18:40:16.370 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.deployer.kar/4.0.8
2017-08-18 18:40:16.372 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.diagnostic.core/4.0.8
2017-08-18 18:40:16.404 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.features.command/4.0.8
2017-08-18 18:40:16.408 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.http.core/4.0.8
2017-08-18 18:40:16.438 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.instance.core/4.0.8
2017-08-18 18:40:16.530 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.jaas.command/4.0.8
2017-08-18 18:40:16.532 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.0.8
2017-08-18 18:40:16.538 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.0.8
2017-08-18 18:40:16.546 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.kar.core/4.0.8
2017-08-18 18:40:16.565 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.log.core/4.0.8
2017-08-18 18:40:16.568 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.package.core/4.0.8
2017-08-18 18:40:16.579 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.scr.command/4.0.8
2017-08-18 18:40:16.583 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.service.core/4.0.8
2017-08-18 18:40:16.618 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.shell.commands/4.0.8. Missing dependencies: [org.jledit.EditorFactory]
2017-08-18 18:40:16.807 [INFO ] [ll.impl.action.osgi.CommandExtension] - Command registration delayed for bundle org.apache.karaf.shell.ssh/4.0.8. Missing dependencies: [org.apache.sshd.SshServer]
2017-08-18 18:40:16.812 [INFO ] [pache.sshd.common.util.SecurityUtils] - BouncyCastle not registered, using the default JCE provider
2017-08-18 18:40:16.820 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.system.core/4.0.8
2017-08-18 18:40:16.877 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.commands/4.0.8
2017-08-18 18:40:16.895 [INFO ] [j.pax.web.service.internal.Activator] - EventAdmin support enabled, servlet events will be postet to topics.
2017-08-18 18:40:16.897 [INFO ] [j.pax.web.service.internal.Activator] - LogService support enabled, log events will be created.
2017-08-18 18:40:16.899 [INFO ] [j.pax.web.service.internal.Activator] - Pax Web started
2017-08-18 18:40:16.992 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.shell.ssh/4.0.8
2017-08-18 18:40:17.032 [INFO ] [org.eclipse.jetty.util.log ] - Logging initialized @2298ms
2017-08-18 18:40:17.216 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.apache.karaf.wrapper.core/4.0.8
2017-08-18 18:40:17.271 [INFO ] [rvice.jetty.internal.JettyServerImpl] - Pax Web available at [0.0.0.0]:[8443]
2017-08-18 18:40:17.272 [INFO ] [vice.jetty.internal.JettyFactoryImpl] - SPDY not available, creating standard ServerConnector for Http
2017-08-18 18:40:17.273 [INFO ] [rvice.jetty.internal.JettyServerImpl] - Pax Web available at [0.0.0.0]:[8080]
2017-08-18 18:40:17.280 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [9]] to http service
2017-08-18 18:40:17.342 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.io.rest.docs_2.1.0 [194]] to http service
2017-08-18 18:40:17.384 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:17.423 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.1.0 [194], contextID=default], with context-name:
2017-08-18 18:40:17.483 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.1.0 [194], contextID=default]}
2017-08-18 18:40:17.502 [INFO ] [org.eclipse.jetty.server.Server ] - jetty-9.2.19.v20160908
2017-08-18 18:40:17.545 [INFO ] [.jetty.server.handler.ContextHandler] - Started o.e.j.s.h.ContextHandler@66800add{/static,null,AVAILABLE}
2017-08-18 18:40:17.599 [INFO ] [eclipse.jetty.server.ServerConnector] - Started 0.0.0.0:8443@10bc9073{SSL-http/1.1}{0.0.0.0:8443}
2017-08-18 18:40:17.603 [INFO ] [eclipse.jetty.server.ServerConnector] - Started default@743d90eb{HTTP/1.1}{0.0.0.0:8080}
2017-08-18 18:40:17.603 [INFO ] [org.eclipse.jetty.server.Server ] - Started @2869ms
2017-08-18 18:40:17.633 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.ui.dashboard_2.1.0 [170]] to http service
2017-08-18 18:40:17.640 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:17.646 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.1.0 [170], contextID=default], with context-name:
2017-08-18 18:40:17.659 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.1.0 [170], contextID=default]}
2017-08-18 18:40:17.663 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.178.20:8080
2017-08-18 18:40:17.664 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.178.20:8443
2017-08-18 18:40:17.983 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.core.audio_0.9.0.b5 [99]] to http service
2017-08-18 18:40:18.003 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:18.008 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.b5 [99], contextID=default], with context-name:
2017-08-18 18:40:18.011 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.b5 [99], contextID=default]}
2017-08-18 18:40:18.100 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:18.104 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [9], contextID=default], with context-name:
2017-08-18 18:40:18.108 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [9], contextID=default]}
2017-08-18 18:40:18.165 [INFO ] [org.quartz.impl.StdSchedulerFactory ] - Using default implementation for ThreadExecutor
2017-08-18 18:40:18.196 [INFO ] [rg.quartz.core.SchedulerSignalerImpl] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
2017-08-18 18:40:18.196 [INFO ] [org.quartz.core.QuartzScheduler ] - Quartz Scheduler v.2.2.1 created.
2017-08-18 18:40:18.197 [INFO ] [org.quartz.simpl.RAMJobStore ] - RAMJobStore initialized.
2017-08-18 18:40:18.198 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler meta-data: Quartz Scheduler (v2.2.1) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED'
Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 2 threads.
Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered.
2017-08-18 18:40:18.199 [INFO ] [org.quartz.impl.StdSchedulerFactory ] - Quartz scheduler 'openHAB-job-scheduler' initialized from specified file: '/opt/openhab/openhab2_Testsystem_2-1/runtime/etc/quartz.properties'
2017-08-18 18:40:18.199 [INFO ] [org.quartz.impl.StdSchedulerFactory ] - Quartz scheduler version: 2.2.1
2017-08-18 18:40:18.199 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
2017-08-18 18:40:20.211 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.items'
2017-08-18 18:40:20.242 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'StartUp' has been added.
2017-08-18 18:40:20.263 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'TestSwitch' has been added.
2017-08-18 18:40:20.265 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'Result' has been added.
2017-08-18 18:40:20.464 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2017-08-18 18:40:21.841 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'two.rules'
2017-08-18 18:40:22.049 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'one.rules'
2017-08-18 18:40:22.227 [INFO ] [org.quartz.core.QuartzScheduler ] - JobFactory set to: org.eclipse.smarthome.model.rule.runtime.internal.engine.GuiceAwareJobFactory@6d03497a
2017-08-18 18:40:22.228 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED paused.
2017-08-18 18:40:22.446 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.things'
2017-08-18 18:40:22.448 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'main.things' is either empty or cannot be parsed correctly!
2017-08-18 18:40:22.506 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Strip_Brightness-milight:rgbLed:ACCF23DBA370:5:ledbrightness' has been added.
2017-08-18 18:40:22.507 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'LocalSun_Rise-astro:sun:local:rise#start' has been added.
2017-08-18 18:40:22.508 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'FernseherWZ_ButtonPress-harmonyhub:device:Wohnzimmer:36437306:buttonPress' has been added.
2017-08-18 18:40:22.520 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'HABServer192168178190_Online-network:device:192_168_178_190:online' has been added.
2017-08-18 18:40:22.521 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'LocalTime_Date-ntp:ntp:local:string' has been added.
2017-08-18 18:40:22.523 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Bulb_Brightness-milight:whiteLed:ACCF23DBA370:1:ledbrightness' has been added.
2017-08-18 18:40:22.665 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui_0.9.0.b5 [136]] to http service
2017-08-18 18:40:22.749 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:22.762 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.b5 [136], contextID=default], with context-name:
2017-08-18 18:40:22.810 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.b5 [136], contextID=default]}
2017-08-18 18:40:22.845 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui.icon_0.9.0.b5 [137]] to http service
2017-08-18 18:40:22.852 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:22.861 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.b5 [137], contextID=default], with context-name:
2017-08-18 18:40:22.864 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.b5 [137], contextID=default]}
2017-08-18 18:40:22.931 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.jupnp_2.2.0 [162]] to http service
2017-08-18 18:40:22.962 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:22.967 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@5adbbc8d, with context-name:
2017-08-18 18:40:22.981 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@5adbbc8d}
2017-08-18 18:40:23.083 [INFO ] [ll.impl.action.osgi.CommandExtension] - Registering commands for bundle org.openhab.core.karaf/2.1.0
2017-08-18 18:40:23.522 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui.basic_0.9.0.b5 [190]] to http service
2017-08-18 18:40:23.527 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:23.532 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.b5 [190], contextID=default], with context-name:
2017-08-18 18:40:23.547 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.b5 [190], contextID=default]}
2017-08-18 18:40:23.739 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-08-18 18:40:23.860 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui.classic_0.9.0.b5 [191]] to http service
2017-08-18 18:40:23.894 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:23.908 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.b5 [191], contextID=default], with context-name:
2017-08-18 18:40:23.915 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.b5 [191], contextID=default]}
2017-08-18 18:40:23.917 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-08-18 18:40:23.980 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.eclipse.smarthome.ui.paper_0.9.0.b5 [192]] to http service
2017-08-18 18:40:23.990 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:23.993 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.b5 [192], contextID=default], with context-name:
2017-08-18 18:40:23.998 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.b5 [192], contextID=default]}
2017-08-18 18:40:23.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-08-18 18:40:24.306 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Binding bundle: [org.openhab.core_2.1.0 [166]] to http service
2017-08-18 18:40:24.315 [INFO ] [rg.ops4j.pax.web.utils.ClassPathUtil] - Ignoring bundle scan for /META-INF/services javax.servlet.ServletContainerInitializer.
2017-08-18 18:40:24.320 [INFO ] [ce.jetty.internal.HttpServiceContext] - registering context DefaultHttpContext [bundle=org.openhab.core_2.1.0 [166], contextID=default], with context-name:
2017-08-18 18:40:24.339 [INFO ] [.jetty.server.handler.ContextHandler] - Started HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.1.0 [166], contextID=default]}
*** HERE WE GO ***
** Startup rule is triggered by 'System started' **
2017-08-18 18:40:27.740 [DEBUG] [eclipse.smarthome.model.script.RULES] - +++ Rule 'StartUp' started +++
2017-08-18 18:40:27.747 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'StartUp' received command OFF
2017-08-18 18:40:27.754 [INFO ] [marthome.event.ItemStateChangedEvent] - StartUp changed from NULL to OFF
** Manually trigger TestSwitch via REST while Thread::sleep is counting -> Rule 'Test' is NOT triggered**
2017-08-18 18:40:35.972 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
2017-08-18 18:40:35.973 [INFO ] [marthome.event.ItemStateChangedEvent] - TestSwitch changed from NULL to ON
2017-08-18 18:40:41.306 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
2017-08-18 18:40:46.807 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
2017-08-18 18:40:54.508 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
2017-08-18 18:41:12.447 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
** Thread::sleep is over -> change item 'StartUp' immediately followed by another Thread:sleep -> rule 'Test2' is NOT triggered **
2017-08-18 18:41:27.753 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'StartUp' received command ON
2017-08-18 18:41:27.763 [INFO ] [marthome.event.ItemStateChangedEvent] - StartUp changed from OFF to ON
2017-08-18 18:41:30.753 [DEBUG] [eclipse.smarthome.model.script.RULES] - --- Rule 'StartUp' completed ---
** What is this? **
2017-08-18 18:41:30.758 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
** Rule 'Startup' finished **
2017-08-18 18:41:30.758 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'StartUp' received command OFF
2017-08-18 18:41:30.761 [INFO ] [marthome.event.ItemStateChangedEvent] - StartUp changed from ON to OFF
** Manually trigger TestSwitch via REST -> Rule 'Test' is triggered**
2017-08-18 18:41:31.132 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'TestSwitch' received command ON
2017-08-18 18:41:31.153 [DEBUG] [eclipse.smarthome.model.script.RULES] - +++ Rule 'Test' started +++
2017-08-18 18:41:31.155 [DEBUG] [eclipse.smarthome.model.script.RULES] - --- Rule 'Test' completed ---
2017-08-18 18:41:31.157 [INFO ] [marthome.event.ItemStateChangedEvent] - Result changed from NULL to Test rule triggered via REST
So, I’m not a developer but it seems I can reproduce this behaviour. Or am I missing something?
Cheers
Sebastian
