I have a switch for my front door to open on my default sitemap:
Switch item=FrontDoorOut label="FrontDoor: " icon=“frontdoor”
works fine with http binding, but I had some unintentionally clicks. So I want a question before switching. how can this be done ?
thanks in advance
Use the Telegram binding - scroll to the bottom of this page for a question/answer example:
You can do this by setting up a proxy item. With this configuration only if the security trigger is turned on the real item gets shown. Then you can trigger that.
Items:
Switch System_RestartOpenHABTrigger "Sicher?" <settings> {channel="exec:command:Command_OpenHAB_Reboot:run"}
Switch System_RestartOpenHABSafety "Restart" <settings>
Sitemap
Switch item=System_RestartOpenHABSafety
Switch item=System_RestartOpenHABTrigger mappings=[OFF="NEIN", ON="JA"] visibility=[System_RestartOpenHABSafety==ON]
In addition you need this rule to turn the security item off when the real item gets triggered
rule "Reboot OpenHAB zurücksetzen"
Item System_RestartOpenHABTrigger received command
System_RestartOpenHABSafety.sendCommand(OFF)
ok, thanks for your reply.
I want to use it for my FrontDoor:
how can I use this. actually my item:
String FrontDoorOutValue { http=“<[beckhoff:2000:JSONPATH($.FrontDoor)]” }
Switch FrontDoorOut { http=“>[ON:POST:https://raspberrypi/beckhoff/xxx.php?frontdoor=true {Authorization=Basic xxx==}] >[OFF:POST:https://raspberrypi/beckhoff/postdata.php?frontdoor=false {Authorization=Basic xxxx==}]” }
my rule:
rule “frontdoor1”
Item FrontDoorOutValue received update
FrontDoorOut.postUpdate(if(FrontDoorOutValue.state == “on”) ON else OFF)
my sitemap:
Frame label=“doors” {
Do I have to use my FrontDoorOut Switch to change with your SystemRestartOpenHABTrigger ?
rpwong
(Russ)
November 20, 2020, 7:29pm
5
If you just want two clicks to lock or unlock your door, nest the door item in a text item on your sitemap.
Text item=FrontDoorOut label="Front Door" icon=“frontdoor” {
First of all: Please use code fences
Here are your configurations:
*.items
String FrontDoorOutValue { http="<[beckhoff:2000:JSONPATH($.FrontDoor)]" }
Switch FrontDoorOut { http=">[ON:POST:https://raspberrypi/beckhoff/xxx.php?frontdoor=true{Authorization=Basic xxx==}] >[OFF:POST:https://raspberrypi/beckhoff/postdata.php?frontdoor=false{Authorization=Basic xxxx==}]" }
Switch FrontDoorSafety
*.sitemap
Switch item=FrontDoorSafety
Switch item=FrontDoorOut label="FrontDoor: " icon=“frontdoor” visivbility=[FrontDoorSafety==ON]
*.rules
rule “frontdoor1”
rule "FrontDoor reset"
Item FrontDoorOutValue received command
FrontDoorSafety.sendCommand(OFF)
thanks for your reply. works fine! No question, but structured behind icons. The only thing is that I can’t see the actual status immediately. but it’s ok.
