It’s strange that there a switches in the “on” position with a question mark. Do the question marks disappear when you manually refresh the page by pulling down?
No it stays the same on few items. This occured around 2 weeks ago, before it was fine.
And the behavior for these items is different when on off is triggered elsewhere, the app does not get updated.
E.g when checking on app and PC browser running openhab ui:
App turn On - PC browser state turns On
PC browser turn On - No effect on app
==> events.log <==
2023-05-27 11:34:35.035 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303' received command ON
2023-05-27 11:34:35.039 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' received command ON
2023-05-27 11:34:35.040 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'KitchenSonoffRFR303_SonoffRFR303' predicted to become ON
2023-05-27 11:34:35.043 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' changed from OFF to ON
2023-05-27 11:34:41.153 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303' received command OFF
2023-05-27 11:34:41.155 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' received command OFF
2023-05-27 11:34:41.156 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'KitchenSonoffRFR303_SonoffRFR303' predicted to become OFF
2023-05-27 11:34:41.158 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' changed from ON to OFF
From Browser:
2023-05-27 11:35:41.273 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' received command ON
2023-05-27 11:35:41.274 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'KitchenSonoffRFR303_SonoffRFR303' predicted to become ON
2023-05-27 11:35:41.277 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' changed from OFF to ON
2023-05-27 11:35:45.502 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' received command OFF
2023-05-27 11:35:45.504 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'KitchenSonoffRFR303_SonoffRFR303' predicted to become OFF
2023-05-27 11:35:45.507 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KitchenSonoffRFR303_SonoffRFR303' changed from ON to OFF
