Hello. I would like to trigger a certain KNX scene whenever an “ON” command is received on a certain item. I would like to use the JS rule builder.
Now I can use changed().toOn(), but I believe that this does not trigger the scene repeatedly when the state is ON already - yet this is what I want.
I can use receivedCommand() but then how can I access the command (ON/OFF) that was actually received? Is there support for this?
